Apologies for starting two threads asking for help - in the event that I see a question I can answer, I'll do my best to answer it. I've read the userguides and so on and can't find an answer to this.
Is it possible, in subtitle workshop, Aegisub or anything, to add subtitles of varying colours? By which I mean one line will be white, then another yellow, etc. This is to differentiate between speakers. All I can find is a way to change the colours for the entire file - and I'm not interested in shading and so on, I just want plain white or yellow, green or cyan.
It's actually easy to do. I typically use a standard text editor to do it, however.
The easiest way to do it is using styles in .ass, where you can set the color in each style (text, outline, shadow and background colors), then you just use that style for the line of text you are timing. You define a "Default" style, and then anything else you want to make different is defined with a different style name. If you want, this is an excellent way to define a different color for each character in a movie, thereby, dialogue off-screen is still easily identifiable.
Of course, this means the style is applied to the whole line(s). In this form, the colors are defined as AABBGGRR, where AA is the transparency/alpha.
For greater control, there are "slash" tags that can be done inline. However, I haven't used them, yet, and haven't actually found a comprehensive guide to the tags.
You might wish to find a couple of complicated .ass files from some anime sites to see how this is done. The styles are defined usually near the very top of the file, and are very easy to understand. -
Do note that support for ass (Sub Station Alpha) subtitles is not so great on playback devices like DVD and BluRay players and media streamers. If you're planning to play on a PC that's no problem, but you might want to do a test on your playback device to be sure that ass subs are supported and that colors work if you plan to play it on something other than PC.
adding subtitles to 3D .iso
By THX-UltraII in forum SubtitleReplies: 4Last Post: 9th Jun 2015, 03:46 -
Help with converting video / adding subtitles - subtitles are off from audi
By kurohoshi in forum Video ConversionReplies: 0Last Post: 27th Dec 2010, 15:53 -
adding subtitles
By dabud in forum Authoring (DVD)Replies: 3Last Post: 20th Oct 2009, 22:27 -
Adding subtitles
By tommcd64 in forum Authoring (DVD)Replies: 7Last Post: 28th Aug 2009, 00:39 -
Adding subtitles
By Avril in forum MacReplies: 14Last Post: 18th Jan 2009, 13:43
