Hi,
I have a couple of QuickTime movies and mpegs and need to put them into DVD. The thing is, one of them is very good quality and the others rather fair. I put them all in Toast 10, set the encoding parameters to the best quality, and the HQ movie ends up not so good in the DVD. As if the lesser quality files "drag it down"...I say this because when I encode only the HQ movie and play the DVD, the quality is fine. Is there a way to encode all movies and the resulting DVD coming out with each movie as good or as bad as it came in ?
Thanks,
Wendy ? I'm home !
Thanks Baldrick,
but...I really don't want different quality settings for each clip...what I want is, if a clip is very good on Quicktime player, to come out very good on the DVD, and if a clip is fair or bad, well, to look likewise on the DVD. What happens is that the good clip/clips look worse after encoding, even if the quality set to maximum. Shouldn't Toast deliver a simple request as this ?
Regards,Wendy ? I'm home ! -
How many minutes are you trying to put on one dvd? If too many(above 2 hours) it wont be that good.
Oh it is ridiculously short...around 10 minutes. I make a DVD just for the convenience of the person who has to see it. Either Toast or I are doing something wrong, since the mpeg looks great on QT and pixelated and a bit blurry once encoded to DVD with highest quality settings.
Wendy ? I'm home !
Video Resolution Decreases when Upload on Utube.
By ScorpionBlues in forum Video Streaming DownloadingReplies: 2Last Post: 25th Mar 2011, 13:01 -
WMV files equal to DVD quality
By uniks in forum Newbie / General discussionsReplies: 3Last Post: 23rd Apr 2010, 11:16 -
Kodak Zx1 - Problem Playing MOVs Created with FFMPEG
By misnardi in forum Newbie / General discussionsReplies: 8Last Post: 6th Apr 2010, 21:50 -
Rendering with Adobe Premiere Elements decreases visual quality
By AuditSup in forum Newbie / General discussionsReplies: 17Last Post: 27th Mar 2010, 13:37 -
Making mutilple MPGs from Avi Files
By funkymix in forum ffmpegX general discussionReplies: 2Last Post: 16th Mar 2009, 23:37
