I try to capture a clip from a camcorder tape to my pc with stoik and the results via my firewire is god.
But when i try to convert it, it ends up with that the audio is half the speed than the video is,
The source is 720x576, 25.000 fps and the audio 16bit, 48khz 2 channel.
I tried with tmpgenc but for some reason it puts out the audio halv the speed aganst what the video is, i don't know why!
Please help!
What version of TMPGEnc are you using? I assume PCM audio from a camcorder? I haven't used TMPGEnc for a while, but when I did, I did all my editing in DV format, then converted just the video with TMPGEnc and used ffmpegGUI or Aften separately to convert the audio to AC3 to save a bit of space. Then used TMPGEnc Author to mux the audio back with the video when converting to DVD. Make sure you allow for the audio size when encoding the video if you plan to use a DVD.
But others here may have a different method.
And welcome to our forums.
Help!!! Converted video drops audio about half way through.
By jimwelch1957 in forum Video ConversionReplies: 2Last Post: 23rd May 2010, 05:52 -
All video playing half speed?!
By MJ Peg in forum Software PlayingReplies: 8Last Post: 2nd Mar 2010, 11:07 -
:?: half-speed play with no audio pitch change?
By gregconquest in forum Software PlayingReplies: 8Last Post: 10th May 2008, 22:21 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 08:35 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 10:55
