    Dec 2009
    I'm trying to convert my copy of Kung Fu Panda into a Mp4 file using RipBot. I tried using the ripped m2ts files, it somehow picked the wrong audio track and it ended up in French. I then tried tsmuxer. There's a bunch of AC3 files, which I think are the foreign languages and a TrueHD that's the English. When I used the TrueHD, the audio was out of synch by a minute or so. When I used the AC3 files it worked well, but it's not in the right language. How do I get the TrueHD to work with RipBot. One thing I did notice was after RipBot finished coding, it hung on muxing the audio. I let it sit there for hours and it never finished. I don't know if it means anything, but I noticed it. Anyone have any insight? Thanks for any help.
    Try extract the audio with clown_bd(eac3to frontend) instead and see if it makes any difference.
    Or try convert to mp4 with bdrebuilder.
    Dec 2009
    Thanks Baldrick. I ran it again. I'm not exactly sure what I did different this time, but it worked. It's still hanging on muxing, which I don't understand. I'll be back when I get stuck again, which I'm sure is not that far off since I'm kind of a newb with this stuff. Thanks again.
