I have a Sony mini DVD camcorder and I need to cut out about 5 minutes of video and burn that to a dvd for someone. What/how is the best way to do this in Windows 7? It has been years since I did this and I think I used TMPgenc to do it back then. I think the last time I did it, still back in the Windows XP days, was to used something to rip the dvd to the hd and then I used Virtual Dub to rip it out.
Are there any freeware solutions to do it with? If not, then what is the best solution?
Thanks!
DVD Shrink is possibly the easiest method.
Open the disc in Shrink, click re-author, and drag the title that the clip is in form the right to left hand pane.
Right-click on the title and select Set Start and End Points, then isolate the clip you want to keep. Click OK.
Click on Backup, and save the results to a folder. Shrink will give you a DVD structure ready for burning.Read my blog here.
Thanks for the tips. Wow! That was easy. Now that I got it cut and ripped, I burned it using ConvertXtoDVD3 and seems like I have an audio issue in the middle of the video clip. Beginning of it is good, but in the middle it sounds like it is stuttering really bad.
Why did you use ConvertXtoDVD ? The results of Shrink, if used correctly, should have been a compliant DVD structure, including a Video_TS folder. Just load this into Imgburn and burn your DVD. No need for ConvertXtoDVD at all in this process.
Read my blog here.
Cut Out Segments Of Video Using Womble MPEG Video Wizard DVD
By luckyace in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2017, 04:46 -
Last few minutes of video frozen...
By JohnC1726 in forum RestorationReplies: 3Last Post: 14th Jan 2010, 09:56 -
How to cut out the text on a dvd video
By tealmarlin in forum EditingReplies: 1Last Post: 9th Nov 2009, 13:27 -
Run TV and have DVD player cut in every 15 minutes?
By kevinreddog in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Jan 2008, 08:31 -
Video crashes after a few minutes
By Diego123 in forum Software PlayingReplies: 16Last Post: 4th Jan 2008, 11:04
