Hi everyone. This is my first post and am really new to the video editing world so please excuse me if some of my questions seem stupid.
I have a HD mini cam that records in an MTS format and a gopro cam that is MP4. I can edit the MTS on its own and the MP4 on its own but i cannot combine the two file types. For the editing i use Sony Vegas. Can anyone give me some insight on how i can do this. Thanks
Michael
It should be possible to create a project in Sony Vegas and then :- (i) load both the MTS files and the MP4 files into that project (ii) edit the material as you wish (iii) render the project to suit your needs.
Since I read your post I have tried this using Vegas Movie Studio Platinum Pro 9.0 . I seemed to work OK but I had no new MP4 file to use. I had to make one by converting an MTS file to MP4 using XMediaRecode and to guess the parameters to use. I do not know if this constitutes a valid test. You may also have to experiment with settings to avoid bad artefacts.
Bye the way if your cameras use SD cards (or mini DVDs) I recommend copying the files directly from the media into your computer by drag and drop . It is probably easier than using a cable and capture software.
good luck from Mike L
Combining MP4 files downloaded via rtmpe
By Cwluc in forum EditingReplies: 2Last Post: 4th Feb 2012, 21:37 -
Combining MP4 files (h264) with mencoder results in blank (white) videos
By mstaker in forum Video ConversionReplies: 0Last Post: 10th Dec 2011, 14:35 -
Help seamlessly re-combining .mts files without a playlist
By and in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 17th Nov 2011, 13:08 -
how to handle mp4 and mts(canon) files.
By dainova in forum EditingReplies: 1Last Post: 9th Aug 2010, 05:25 -
Combining MP4 files
By Shaba1 in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2009, 17:46
