I have a movie saved as 32 avi files,each about 4GB's,total 117GB's. What can I use to join them into one file?
If audio and video settings and codecs are identical VirtualDub or AviDemux. The latter is a little more forgiving of slight differences.
I downloaded the most recent version of Virtual Dub and it allowed me to join all the avi's into one file. What I didn't know was that Virtual Dub will automatically add all the files. Select the first file,then select direct stream copy,then "append" the second file and the program automatically adds all the files. Then select save as avi and it saved as one file,in my case it was 119GB's.
joining avi files
By dugen in forum MacReplies: 1Last Post: 11th Jun 2011, 12:47 -
Joining avi files
By carlmart in forum Video ConversionReplies: 13Last Post: 29th May 2009, 07:35 -
Joining avi files?
By tofuguy in forum EditingReplies: 4Last Post: 7th Oct 2008, 02:30 -
Joining avi files?
By t_jay17 in forum EditingReplies: 5Last Post: 18th Dec 2007, 12:22 -
joining avi files
By king2136 in forum Authoring (DVD)Replies: 4Last Post: 1st Oct 2007, 14:30
