I've stripped a commercial BD - see streams below. I'm trying to create an NTSC 29,97fps DVD-9.
Question: how do I keep original sound and get best video quality?
Video
Format : VC-1
Format profile : AP@L3
Codec ID : WVC1
Codec ID/Hint : Microsoft
Duration : 1h 46mn
Bit rate : 20.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.402
Stream size : 14.8 GiB (98%)
Language : English
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
Codec ID : A_AC3
Duration : 1h 46mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 486 MiB (100%)
Title : 3/2+1
Language : Portuguese
Thanks !!!
If you are trying to make an ACTUAL dvd than you can't get "best video quality". It will be standard definition video at 720x480/576.
As for original audio you can't do that either if you are making an actual dvd also - max of 448kpbs for dolby digital - you can do 1510kpbs for dts but you need a dts encoder to downconvert to regular dts from hd dts and dts encoders are not cheap.
You can still get good quality with sd video and sd digital audio but you will not keep hd nor top quality.
Do you have a bluray player that can play avchd? if so you can convert to that format with multiavchd. But it will only be playable in bluray players or computers that can play avchd.
fyi you can use the freeware program avstodvd to create a dvd from a bluray. - edit multiavchd can also make a sd dvd from bluray your choice of which to use - both freeware and both can do user created menus.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thnks for reply, yoda313 !
For the record: I'm trying to get best quality "possible" in a DVD-9 NTSC 29,97fps format.
As I said, I've got the two original streams stripped from commercial blu-ray and waht I want is to encode video and then audio and then mux the result to burn a DVD-9.
What I need to know is: which apps and what settings are better to encode video and audio and then multiplex. May be free or not free apps.
Once again, thanks !
How we maintain original vido quality of vhs while we create dvd from it
By nusratjaveid in forum Capturing and VCRReplies: 5Last Post: 11th May 2011, 22:52 -
BD to DVD-9 - how do I keep original sound and get best video quality?
By rilopes in forum Video ConversionReplies: 0Last Post: 31st Oct 2010, 16:53 -
Remove Sound From Original DVD And Add My Own Sound To New DVD.
By MrJacobAngle in forum Authoring (DVD)Replies: 7Last Post: 30th Jun 2010, 15:38 -
Capture stereo sound and quality video from analog camcorder to dvd
By gxwarr in forum Video ConversionReplies: 1Last Post: 6th May 2009, 17:39 -
Saving files in original quality in MPEG Video Wizard DVD
By guy24s in forum Newbie / General discussionsReplies: 12Last Post: 5th Sep 2007, 17:30
