HI I`M USING A PANASONIC SC-PT175 HOME CINEMA SURROUND SYSTEM
I BAUGHT A 32GB USB STICK{ NOT SURE WOT MAKE IT IS }
I HAVE FORMATTED IT USING FAT 32 .THE PROBLEM IS THAT SOME AVI FILES ARE WORKING AND OTHERS ARNT.
THE FILES THAT ARE WORKIN ARE 624x352
BIT RATE 121KPS
SIZE 349MB
I HAVE ABOUT 11 OF THEESE ON THE STICK AS SOON AS I ADD A LARGER FILE LETS SAY ABOUT 700MB THE PLAYER KEEPS SAYING ERROR BUT THE OTHER FILES ARE WORKING FINE
THE CODEC I`M USING ON MY PC IS THE FFDSHOW
I`VE HAD THE LARGER FILES PLAYING B4 EG 700 MB -1.4GB
SO WAT IS IT THAT I`M DOING WRONG
Read the sticky here.
https://forum.videohelp.com/threads/290800-My-DivX-DVD-Player-can-t-play-my-avi-DivX-xvid-video
Welcome to the forums, but should you post in the future please don't use all caps. It's considered rude.
Looking for DVD player w/USB that will recognize DVD menus through USB
By b20828 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 30th Dec 2010, 10:43 -
Playing Video Files on DVD Player with USB
By Seachd12 in forum Video ConversionReplies: 5Last Post: 20th Dec 2010, 11:04 -
Watching my MKV files via USB on my blu ray player
By JulesWinnfield in forum Newbie / General discussionsReplies: 7Last Post: 19th Oct 2009, 18:15 -
Best DVD Player for Playing AVI files via USB (5990 vs 5960)
By shobuddy in forum DVD & Blu-ray PlayersReplies: 16Last Post: 14th Feb 2009, 13:43 -
Can I play video files from my PC HD, through my DVD player,using USB port?
By fgtan in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 15:10
