Hi!
I've recorded a TS stream with my DVB-S receiver.
Then I've demuxed this TS file with ProjectX and got now these files:
*.m2v
*.ac3
*.mp2
Now my question:
Is it possible to compress these data files further, e.g. using h.264 codec?
At the end I want to have a video file that can be easily played with a media player that supports the used video codec and that takes less disk space.
Can you please help me?
According to MediaInfo, the video file is
MPEG2 with 720x576, 25000 FPS
Is it possible to apply the approach for SD video streams also for HD video streams?
THX
	720x576/25 looks like a DVD or maybe a digital broadcast.
 You can compress the m2v (Mpeg2) to divx/xvid/h.264 to specs your media player will accept. Then remux with the audio.
 HD TS broadcast streams are usually MPeg2 in ATSC/DVB but for DVB h.264 is also used in some areas.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
  change aspect ratio & convert m2ts files & brighten videosBy rockerman in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2011, 08:34
  Need help with Audio stream format, VD/M won't compressBy talefing in forum Newbie / General discussionsReplies: 7Last Post: 15th Mar 2010, 13:22
  How to compress mpa streamBy jeby1980 in forum AudioReplies: 2Last Post: 23rd Feb 2010, 18:01
  Compress Webcam Video Stream (Video Conference)By wxrkny in forum Newbie / General discussionsReplies: 1Last Post: 6th May 2008, 00:11
  whats a good program to use to convert/compress to h264By cowboysroy31 in forum Video ConversionReplies: 1Last Post: 20th Jun 2007, 19:28
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
