Hi all,
I am trying hard to find what compression method is used in MPEG2-TS. On a wiki page (link given below) it 'appears' to be h.262 but I am not so sure as the wording is vague.
http://en.wikipedia.org/wiki/MPEG-2
I also found out that the compression method used in MPEG is DCT and block-based scheme with motion compensation. Does it mean that MPEG2-TS have the same compression method?
On a forum, I found out that typically h.264 is used for compression in MPEG2-TS .
So which one is it?
Thanks in advance
MPEG 2 transport streams can contain both h.262 (MPEG 2, part 2) and h.264 (MPEG 4, part 10). And maybe others. MPEG 1, MPEG 4 part 2 (ASP, Divx, Xvid)?
I just muxed an MPEG 1 stream into a M2TS file with TsMuxer. So I guess MPEG 1 is supported.Last edited by jagabo; 1st Nov 2010 at 07:06.
HD mpeg2 transport stream re-quantization?
By live4ever in forum DVB / IPTVReplies: 2Last Post: 21st Jul 2009, 19:25 -
Help Please: Looking for MPEG2-ts (Transport Stream) Recovery Software
By Moon43 in forum ComputerReplies: 13Last Post: 11th May 2009, 15:20 -
MPEG2 transport stream software
By PCNG in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2009, 14:10 -
MPEG2 Transport stream HD 1920x1080i specs Help
By stealthProd in forum Video ConversionReplies: 22Last Post: 13th Sep 2008, 01:59 -
need MPEG2 Transport stream and Program stream profiler
By afarun in forum ProgrammingReplies: 3Last Post: 23rd Aug 2007, 01:06
