i would like to be able to use 3tb HDD (internal) in my winxp 32bit system
i know there is limitation to see 2TB in system so i was wondering if i could by creating a 2TB partition and then a 1TB partition (being 2 primary paritions on a 3TB drive) solve the problem?
i have sharkoon usb3.0 hdd dock which i would use it with 3TB drive so by plugging in to this dock i would be able to see 2TB and 1TB partitions.
is there a way to do it like this or not?
how i can format it to these partitions (2TB+1TB) if windows xp 32bit will not see it? (do i need ither PC capable to format it)
thanks for answers
This drive with XP is a big problem; the 2.1TB limit is MBR related, XP itself can handle 16TB partitions. It could go either way, it sees only 2TB or only 1TB. An add-on SATA controller with support for it or a board with the right BIOS and chipset would fix that and you could use the entire 3TB in 1 partition (the retail package for WD's 3TB comes with such a card). If the drive uses advanced format (4k sectors, used by WD, don't know about others), you need to align the sectors after formatting it or you will get degraded perfomance. The manufacturer has a utility to do that or you can use their install utility to clone, partition and align the drive in one operation.
All this applies to an internal drive setup. You'd have to find out whether your dock supports a 3TB drive. Seagate offers an external 3TB.
At this point you might as well upgrade to vista or win7. If you want to stick with an old OS and have lots of storage, you'd be better off with two 1.5TB and span them into one volume using XP's drive management tool. -
Your mobo cannot boot from a 3tb drive (needs UEFI rather than BIOS), Use in an external caddy may be problematic.
The electronic components of the power part adopted a lot of Rubycons.
Trying to share a win 7 connected printer with an XP laptop
By Denvers Dawgs in forum ComputerReplies: 1Last Post: 30th Jul 2011, 12:22 -
Paragon GPT Loader and 3TB on Win XP pro SP3 32bit not working
By deejay.2001 in forum ComputerReplies: 3Last Post: 13th Jan 2011, 13:40 -
Why is virtualdub 32bit much slower on windows 7 X64 than winxp 32bit?
By TigerSoul in forum EditingReplies: 4Last Post: 26th Mar 2010, 15:13 -
Q's on partioning a hdd and dual booting XP/vista 32bit and win 7 64bit
By Rudyard in forum ComputerReplies: 0Last Post: 14th Feb 2010, 19:52 -
How arrange folders when external storage connected to the USB of DVP
By barbazuk in forum DVD & Blu-ray PlayersReplies: 0Last Post: 23rd Jul 2009, 00:47
