Results 1 to 12 of 12
    Oct 2010
    Surrey,England
    i want to try the filmmachine....but i cannot down load it as it is rar file what free software do i need to open it
    thank you
    Mar 2008
    It's a standard archive file, in use for many years.
    Either Winrar, or 7zip.
    http://www.7-zip.org/
    Sep 2006
    I also 2nd 7zip. There are versions for both 32 & 64 bit and works on Win7.
    Oct 2010
    Surrey,England
    I have down loaded 7zip and has gone into program files
    sorry what do i do now...in the 7zip folder there are a number of files that say application...
    then what do i do to open my rar file thank you
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Did you install 7-zip? It should only be one "7-zip manager" in the start->programs->7-zip. Then open the rar in 7zip manager.
    Or just double click on the rar file and 7zip will open it or right click on the rar file and choose 7-zip->Extract files here....
    Oct 2010
    Surrey,England
    no i have only down loaded 7zip and as i said..down loaded to the program files...how do i install..what do i click on..there are so many folders in the 7zip
    thank you
    Oct 2010
    Surrey,England
    nothing opens on this...
    Nov 2005
    right click on the rar file and you should get this
    Mar 2008
    You install the 7zip program and it should add some items to the right click menu in certain situations.
    The RAR set that you have either has a file suffix such as part01, part02, part03, etc,etc.
    Or is ends with r01,r02....RAR, Or it could be just RAR if it's only one file.
    In the first case, right click on part01 and select extract to...
    in the second case right click on the file that ends in RAR and select extract to...
    If you can't see these file suffix's go into control panel/folder options and deselect "hide file extensions for known file types"
    Oct 2010
    Surrey,England
    Yes thank you i am ok now...
  11. open rar file
