    Feb 2005
    Below is the info from DVDinfo.
    It shows my Verbatim DVD from Fry's to be made by CMC. I thought that was a third level manufacturer.
    I thought Verbatim was first level and just about the best. Now I cannot trust this brand.
    Is Taiyo-Yuden the only name I can trust?
    Media Information
    Disc Regions are 1,2,3,4,5,6,7,8
    Media code/Manufacturer ID CMC MAG. AM3
    Format Type UDF 1.02
    Volume Name KICK_ASS
    Application id
    Implementation id DVD Shrink
    Recording Date/Time (mm/dd/yyyy) 10/25/2010 1:18:05
    Format Capacity 4.36GB(4.68GB)
    Book Type DVD-R
    Media Type DVD-R
    Manufacturer Rated Speed Unknown
    Available Write Descriptor CLV 8.0x 11080KBps
    Available Write Descriptor CLV 4.0x 5540KBps
    Available Write Descriptor CLV 2.0x 2770KBps
    Write Strategy Speed 4.0x 5540KBps
    2x Speed OPC beta 09
    2x Speed OPC power 0D
    2x Write Strategy field 1 14 98 88 90
    2x Write Strategy field 2 88 80 00 00 00 00
    4x Speed OPC beta 07
    4x Speed OPC power 17
    4x Write Strategy field 1 0A 0E 09 04
    4x Write Strategy field 2 95 07 0D 0B
    4x Write Strategy field 3 80 00 00 00
    4x Speed OPC beta multi-pulse 06
    4x Speed OPC power multi-pulse 17
    4x Write Strategy field 4 15 B8 99 85
    4x Write Strategy field 5 B8 9A 32 03 20 32
    4x Write Strategy field 6 00 00 D0 00 00
    Data area starting sector 30000h
    Data area end sector 22E10Fh
    Linear Density 0.267um/bit
    Track Density 0.74um/track
    Number of Layers 1
    Complete Media Code
    00000000 00 F8 00 00 01 40 C1 FD 9E D8 52 00 02 84 0D 12 .....@....R.....
    00000010 98 99 90 00 03 43 4D 43 20 4D 41 00 04 47 2E 20 .....CMC MA..G.
    00000020 41 4D 33 00 05 88 80 00 00 00 02 00 06 09 0D 14 AM3.............
    There is more to life than meets the microscope.
  2. Verbatim from Fry's is their low budget "Life" series, not Datalife of Datalife Plus.
    http://www.frys.com/product/6208150
  3. Banned
    Freedonia
    We've had a lot of discussion for months now on the Verbatim Life series. Guess you missed it. Verbatim has bowed to the pressure of the US marketplace and now uses low quality manufacturers for their cheap Life series of discs. However, the DataLifePlus has not changed. I've been told that the DataLife hasn't changed either, just as jagabo pointed out, but I don't use those discs. I can confirm via a recent order that DataLifePlus is the same as it ever was.
    Nov 2005
    seems the majority of consumers who burn discs dont pay attention to quality so they just grab whatever. If u want the Datalifeplus series...got to supermediastore, they have all of what you want. Burns and quality are as good as they've always been.
