    Nov 2002
    I found this batch command while doing a Google search and it does what I want but names the output files remux-xxx.mkv so I have to manusally remove the remux- from the front of all the file name.
    How do I create the mkvs without remux- at the beginning of every file.
    Here is the command that I'm using...
    FOR %%A IN (*.264) DO mkvmerge -o "remux-%%~nA.mkv" "%%~A"
    I've tried removing remux- from the command but nothing happens when I double click the bat file.
    I have folders full of raw 264 files that I need to mux into separate mkv files.
    1.264
    2.264
    3.264
    etc...
    Nov 2002
    Nevermind. The test files I used had .h264 extensions instead of .264 extensions.
    FOR %%A IN (*.264) DO mkvmerge -o "~nA.mkv" "%%~A"
    works fine on .264 files.
