    Oct 2010
    near Grand Rapids, MI
    I am cheapskate looking into how to get my rather large (300gb+ videos of many various formats, mostly mkv for hd and avi for standard def) video collection onto my TV. The cheapest way I have seen so far would be to purchase a budget blu-ray player, and convert the most important videos in my collection to a compatible format and store them on dvds (buying a bluray burner at the same time as a bluray player would be to expensive for a cheapskate like me :P). Obviousely this is not an ideal solution, since even when I choose just half of the collection it still amounts to 150gb of data all stored on dvds. That would amount to 32 dvds!
    My two questions are: first, are there any better devices that I could purchase for not much more than $150 that would be able to play my video collection without requiring 30+ dvds? The ideal device (obviously not what I expect to find) would be a 1080p supporting video player that also supports most video formats (not to much conversion!) and has an open slot to (here's where it gets a little pipe-dreamy) install the 3.5" sata hard drive I already own that has all my videos contained within it. If there is a device that meets any of these requirements please alert me!
    Secondly, If there are no better device(s), then how would I go about converting my video collection to a blu-ray compatible format? The biggest problem I have run across in the past is aspect ratio. more than half of my video collection uses a non-standard custom aspect ratio. I would assume that bluray players are a lot like dvd players in that they only support a certain number of standard/widely used aspect ratios. If so, how would I convert videos to the correct aspect ratio?
    I am not looking for an easy way to solve this problem, and I will probably not have any troubles understanding how to use most programs as long as it does not require using scripts or coding like avisynth does.
  2. Get a media box e.g. asus oplay, wdtv, popcornhour, ... etc...
    Fewer compatibility issues, no wasted time or quality loss with conversions, huge inexpensive and convienient expandable storage with HDD , no clutter with jewel cases or disc folders ....
  3. May be it is an expensive solution, but new generation LCD or LED HD TVs play many formats including .mkv from their usb port.
