How to chop n edit 1920×1080.300mbps.60fps.AC3 -18.0 Mbps-8ch.mt2s file using free tools or free editors?
Video
Format : MPEG Video
Format profile : 422P@HL
Bit rate mode : Variable
Bit rate : 300 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 59.94 fps
Standard : NTSC
Color space : YUV 4:2:2
Audio
Format : AC-3 / Dolby TrueHD
Format/Info : Audio Coding 3
Bit rate mode : Constant
Bit rate : 18 Mbps
Channel(s) : 8 channels
Sampling rate : 192 kHz
Edit M2TS file ripped from Blu-ray Disc
By seven_deuce offsuit in forum EditingReplies: 3Last Post: 22nd Sep 2009, 21:41 -
Edit M2TS and saving it as M2TS
By Andreas Furumo in forum Video ConversionReplies: 3Last Post: 28th Aug 2009, 15:07 -
Massive M2TS File - Cannot Edit in Premiere
By OmegaNemesis28 in forum EditingReplies: 1Last Post: 31st May 2009, 03:11 -
edit m2ts file with megui audio errors
By scorpio1959 in forum Blu-ray RippingReplies: 3Last Post: 29th Apr 2008, 18:11 -
How to chop out a section in middle of .flv file without reencoding
By Toastie in forum EditingReplies: 0Last Post: 15th Jul 2007, 19:54
