Is it at all possible to burn DVD format into a CDR?
Not space-wise but just format-wise. To try to trick a DVD drive/player into thinking a CDR is actually a DVD disc.
I'm pretty sure it cant be done, but just in case Im wrong, I think its worth the stupid question.![]()
You can make a SVCD with a file that has 720x480 resolution video. However, my DVD player cannot handle 5 Mb/sec data rate from a CD-R. However, if you keep the data rate low, >3 Mb/sec, you should be fine. Check into miniDVD.
OH, ok. I hadn't seen the miniDVD/cDVD page. So, it looks like only 15 mins. will fit into it, eh? Ouch... Disappointing...
I guess I just cant escape having to buy a DVD writer.
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 17:55 -
how do i burn rm files to dvd format?
By sprilite in forum Newbie / General discussionsReplies: 3Last Post: 7th May 2008, 12:41 -
How to burn AVI files onto CDR?
By doofdoofdude in forum Newbie / General discussionsReplies: 2Last Post: 18th Apr 2008, 10:08 -
burn vob into cdr
By pcb in forum Newbie / General discussionsReplies: 10Last Post: 18th Feb 2008, 12:28 -
How Can I burn a 90 min data CDR Image to HD Folder
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2008, 19:48
