Hi,
I am using Adobe Premiere CS 4.2 with Matrox RT.X2 SD card. I have Sony DSR1800 DVCAM deck
conected with firewire to PC.
How I can capture video and all 4 channels of audio from DVCAM tape, using firewire ?
Is it possible somehow to do it in one pass ?
Regards.
that deck may have a manual 4 ch. switch you need to turn on. then if there is 4 ch. audio on the tape it will transfer as one file with the video. it's all interleaved into one file at 32khz/12bit.
I do it 2 channels at a time. Never heard of a way to transfer all 4 in one pass but I'm all ears.
http://www.kiva.org/about -
capture as raw DV. Enosoft DV Processor can if you don't have anything that will.
Thanks, great help, we encode a video (containing 4 language tracks) with 2 channels in stereo, before rendering flick the panning knob so it takes one, then render the other track the same way, and finally encode the video with the remaining 2 tracks and do it all again. It's slow but works to create 4 videos with 4 different language tracks.
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 11:32 -
-acodec copy to 6 channel audio results in 2 channel?
By ninethirty in forum Video ConversionReplies: 1Last Post: 11th Feb 2011, 11:54 -
each audio track on different audio channel or device
By mikedepetris in forum Software PlayingReplies: 2Last Post: 28th Nov 2009, 08:56 -
DVD with mono audio channel...can i convert to two channel
By maass in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2009, 21:46 -
Convert single channel to double channel audio ...
By tariq_niazi in forum AudioReplies: 3Last Post: 15th Nov 2007, 16:47
