I just built a new machine, however I didn't realize my MoBo does not have on-board video. This build is from scratch so I have two clear HDD's and a GPU that needs drivers to work.
The only solution I can think of is take out one of the drives, put that into a dummy machine, load the OS and video drivers onto it and then swap it back into my new machine and it should load fine. Is this correct? Is than an easier solution?
Windows will find whatever graphics card you put in the machine and come up in 640x480 or 800x600 VGA mode. From there you can install drivers from the manufacturer.
Then boot the Windows CD/DVD. The machine always goes through post before booting anything. POST will find whatever graphics card you have and bring it up in text mode.
windows has a generic driver that will work with all cards..vga mode basically...works every time
Well then I must have some connections messed up because my MoBo isn't POSTing
If no post, replug all connectors and cards and RAM. If still no, unplug all cards except the video card and all drives except boot and try again. If still no, substitute RAM. But most motherboards will at least beep with no RAM, video cards or much of anything plugged in. Make sure you have a beep speaker installed. The code may tell you the problem. If still nothing, bad CPU or motherboard? I assume all the fans and lights are working, if not maybe a bad power supply.
I also assume this isn't your first build so you probably didn't overlook some more obvious problems.
CPU and GPU Temperatures?
By neworldman in forum ComputerReplies: 15Last Post: 13th Jun 2011, 17:33 -
x264 soon to be gpu accelerated?
By deadrats in forum Video ConversionReplies: 5Last Post: 12th Sep 2010, 16:52 -
GPU Encoders for WMV
By Yaemish in forum Video ConversionReplies: 1Last Post: 11th Sep 2010, 22:23 -
firefox to soon be gpu accelerated
By deadrats in forum ComputerReplies: 2Last Post: 25th Nov 2009, 22:16 -
Vegas Pro 8 and GPU
By SCDVD in forum EditingReplies: 5Last Post: 23rd Aug 2008, 17:12
