Hello. I have an mkv movie that plays perfectly but it has subtitles which i wish to remove so i used mkvmerge to remove them but the output file wont play, it only displays a black screen. Im using the latest version (4.3.0). Any idea what i can do? Here are the source file stats. Thanks.
Complete name : F:\Downloads\Keira Knightley - Bend It Like Beckham (2002) [HD 720p].mkv
Format : Matroska
File size : 4.36 GiB
Duration : 1h 52mn
Overall bit rate : 5 566 Kbps
Encoded date : UTC 2010-10-11 16:09:03
Writing application : mkvmerge v4.0.0 ('The Stars were mine') built on Jun 6 2010 16:18:42
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 52mn
Bit rate : 3 945 Kbps
Nominal bit rate : 4 056 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 24.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.178
Stream size : 3.09 GiB (71%)
Writing library : x264 core 105 r1724 b02df7b
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4056 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 52mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Resolution : 24 bits
Stream size : 1.18 GiB (27%)
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Closed Thread
How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACT
By lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 15:04 -
Remove subtitles etc from MKV files
By jack616 in forum EditingReplies: 11Last Post: 30th Dec 2013, 01:21 -
How to remove embedded subtitles from mkv
By imars99 in forum SubtitleReplies: 9Last Post: 24th Aug 2011, 03:06 -
Remove any subtitles has an mkv file.
By fits79 in forum SubtitleReplies: 6Last Post: 4th Aug 2011, 17:49 -
Adding .ass subtitles to a MKV file using mkvmerge
By tyson123g in forum SubtitleReplies: 14Last Post: 13th May 2010, 01:03
