Hi all,
I have an MPEG4/AVC video file (see MediaInfo below), and would like to replace its audio with a PCM track. I normally use TMPGenc DVDAuthor, but unable in this case. I see tons of software to convert from VOB to other formats, and it makes more sense than what I want, but in this particular case, I want better audio and not lose video quality by reencoding video.
If anybody has advice, I'd be grateful!
FILE
Format: MPEG-4
Format profile: Base Media / Version 2
Codec ID: mp42
File size: 128 MiB
VIDEO
Format: AVC
Format/Info: Advanced Video Codec
Format profile: High@L3.0
Format settings, CABAC: No
Format settings, ReFrames: 4 frames
Codec ID: avc1
Codec ID/Info: Advanced Video Coding
Thanks for your reply, guns1inger! I just thought of outputting a VOB file because the AVC file is a music video, and most of them on my hard drive are in that format, and that or MPEG2 are the formats TMPGenc DVDAuthor allows (I haven't used other software to just replace audio). If you have any suggestions as to converting to another format without further loss of video quality, I'd be grateful.
If you want it in a DVD ready format then yes, you will have to convert the file. However converting to a VOB on it's own is not recommended. Mpeg-2 is the video format for DVD, VOBs should be produced as the result of a proper authoring process.
However if you just want to change the audio in your current file and play it back from your PC then you don't need to go through these extra (and potentially quality reducing) steps.Read my blog here.
I play the files on a networked media tank, so no need for a standard DVD structure. So YAMB would be an alternative in that case, correct? (assuming PCM will be allowed, if not, I will convert audio to AAC or any other possible format with as little quality loss as possible).
How to convert vob to avi without loosing video quality ?
By RON36 in forum Video ConversionReplies: 4Last Post: 31st Oct 2011, 08:56 -
Which program to use for converting VOB to H.264 MPEG4
By user123456 in forum DVD RippingReplies: 1Last Post: 24th May 2009, 02:20 -
How do you convert the video format from MPEG-layer 3 to MPEG4 SP?
By Conconn in forum Video ConversionReplies: 1Last Post: 2nd Jul 2008, 05:32 -
DVD chaptered VOB's to MPEG4?
By procooper in forum DVD RippingReplies: 1Last Post: 24th Nov 2007, 17:08 -
.img to VOB or avi/mpeg4
By NatDanVideo in forum Newbie / General discussionsReplies: 8Last Post: 13th Sep 2007, 12:09
