:cry: I can convert Svcd files into Mpg2 compatible files but when I author them and burn them to a Dvd-r the sync and the picture seems to go all gobbledygook after deifferent ammounts of time..
I can then restart the film and it will work where it didnt work before...
I cant understand what is causing the problem...
It does these problems on my stand alone dvd player and also on my pc with my hollywood plus card...
Any help is greatly appeciated as this problem is starting to get on my nerves
Cheers
Sean
This will always be a nightmare when you mess with a multiplexed mpeg stream. try to burn the 480x480 files unconverted to a DVD (if you can find a program that will allow you to). If your DVD player will play SVCDs, it should also play a DVD with a SVCD file on it.
compatible files
By woody12 in forum Media Center PC / MediaCentersReplies: 1Last Post: 17th Jan 2011, 11:43 -
890619 - convert TS to VCD compatible files.
By hamidi2 in forum VCDEasy GeneralReplies: 2Last Post: 9th Sep 2010, 17:21 -
converting DVD mini disk files to compatible APPLE format- video is missing
By MovieMom in forum Video ConversionReplies: 2Last Post: 5th Sep 2010, 13:33 -
Here is how to create PS3 Compatible Files with 5.1 Audio
By pogues in forum MacReplies: 1Last Post: 5th Jan 2009, 00:30 -
reclock not compatible with .mkv files?
By THX-UltraII in forum Newbie / General discussionsReplies: 0Last Post: 15th Aug 2008, 06:57
