Results 1 to 9 of 9
rxloren, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz -
You should keep in mind where you intend to play the resulting file. If, for example, it's on an AppleTV or iPod, CABAC won't work (IIRC) so a Handbrake re-encode may be necessary. There are other possible incompatibilities. I tend to use Handbrake and just set it to what I need. Maybe I don't worry about it because Handbrake on an iMac Core i7 is wicked fast.
I'm having stuttering issues with both AVIDEMUX and HANDBREAK in Windows Media Center or Windows Media Player in particular when played in fullscreen. It happens to almost everything I encode with either. I don't kow what to do. I downloaded VLC player and the promlem seems to be resolved. I would like to use WMP because it's the default in Windows Media Center and I enjoy using that interface. Is there anyone else with this problem that can perhaps give me some insight?
Thanks in advance. -
Provide more information about your computer (you might want to fill in the Computer Details section in your VideoHelp profile, if you prefer), and the videos you're attempting to play. If you have an older system, it might have difficulty with HD video. Or, it could be a codec issue - VLC doesn't rely on the codecs/DirectShow filters installed on the system to play videos.
If cameras add ten pounds, why would people want to eat them? -
Yes I do believe it may be the system... although it's a 3 Ghz system with 4 gigs of ram, it's a very low end processor and Graphics unit. Don't know the exact specs... It's a lenovo I used for business which I souped up a bit...720p movies have no problem it's the 1080p ones that are an issue... I suppose I can encode to 720p for now, keeping my sources for when I'm ready to upgrade to a better system for my HTPC. You see, it's my first one, kinda did it to test it and seems to work pretty good... my Dual Core AMD @ 3Ghz and my i7 systems have no problems playing the files...but those are my laptop and gaming systems... I have that "cheepo" for my HTPC... I don't want to go out and get a new HTPC... for now at least,, muahahahahaaa!! but perhaps soon...lol.
Thanks guys.
How to easily convert DVD to high quality MP4/MKV H264 using free tools
By Baldrick in forum User guidesReplies: 45Last Post: 25th Jul 2017, 23:35 -
Mkv to mp4 with handbrake
By hilario in forum Video ConversionReplies: 11Last Post: 5th Feb 2012, 14:27 -
MKV to MP4 converter besides Handbrake
By bowmah in forum Newbie / General discussionsReplies: 10Last Post: 19th Dec 2011, 04:04 -
How to convert to high quality MP4 and display in Flash on your site
By Baldrick in forum User guidesReplies: 8Last Post: 5th Feb 2011, 12:39 -
Convert MKV to AVI/MPEG-2 High Quality file for HD author
By ronorkis in forum Video ConversionReplies: 7Last Post: 1st Nov 2010, 09:23
Thanks for the reply guys.. I'm finding
