For mts file, it defaults to HDMV embedded subtitle.
I have the srt file with the same filename. There is an option in Play -> Subtitle to choose it. However, if I close the player and reopen the file, it goes back to HDMV embedded subtitle.
Any way to change the default behavior?
Results 1 to 1 of 1
Subtitle help with VLC and MPC using DVD and external subtitle
By enigmakid in forum SubtitleReplies: 2Last Post: 2nd Feb 2012, 01:48 -
Force Default Subtitle Style in MPC-HC
By aer in forum SubtitleReplies: 0Last Post: 11th Jun 2011, 18:43 -
Subtitle Creator - Unable to set Default Subtitle Colors & Default Prof
By blue2 in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 23:47 -
Setting MPC-HC as the default player in MCE
By mx5 in forum Software PlayingReplies: 0Last Post: 24th Aug 2009, 23:36 -
how to make a DVD subtitle as a default playing subtitle
By yozloy in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2008, 11:51
