Hi there
Is there any way to do this in Subtitle Workshop? It's the UK broadcast format where the last two numbers refer to frames, but the other numbers refer to times. That means that neither the time or the frame options work, and although there is an option to change the number of digits at the end, it's still time, not frames, so is completely wrong.
I've spent a very frustrating couple of days trying to find any programme that will let me do this. Every single programme I've found is US format with three digits at the end. Surely there must be something out there I can use?
It's possible the paid-for programmes might have this option, but they cost (literally) thousands and aren't even available for download (seriously - Wincaps and Swift are the main ones and you can't download them anywhere at all, legally or not).
This is urgent and I've ended up crying at my computer.![]()
Thank you for your reply. I'll have a look at the Avisnyth software.
I'm not sure what you mean by hardware players.
Why is :00 proprietary but ,000 isn't? -
Consumer software or freeware only supports the subtitle formats that members of the general public normally work with when creating DVDs and various media container files for personal use.
I think the main difficulty is that UK broadcast subtitles are not one of those formats. Since they are a broadcast-only format, only a relatively small number of professionals would normally want to work with them, so only expensive professional tools have been made that specifically support them. Plus, only some parts of the world can use them.
The situation is similar for N. American closed captions. They are both a broadcast and distribution subtitling format, but even if they did find their way into VHS tapes and DVDs, there are few consumer/free software applications that can work with them. One reason for this is that only TVs (and a few DVD recorders/players) made for one region, N. America, can display them.Last edited by usually_quiet; 31st Oct 2010 at 09:39.
Afraid not - I need this as a separate subtitle file with all the info about colours and where the subtitle is placed, etc.
Never mind. Thanks for the responses, guys.
SOLVED: preview, out of sync subtitles behind Subtitle Workshop....
By bahjan in forum SubtitleReplies: 0Last Post: 10th Mar 2012, 05:27 -
subtitle workshop cant read japanese subtitles
By aruwin in forum SubtitleReplies: 4Last Post: 2nd Feb 2011, 09:55 -
How to move subtitles on the screen with Subtitle Workshop
By Lun in forum Newbie / General discussionsReplies: 1Last Post: 7th Oct 2010, 18:31 -
How to synchronize subtitles using Subtitle Workshop?
By devilcoelhodog in forum SubtitleReplies: 4Last Post: 11th Dec 2009, 16:08 -
Need black background behind white subtitles Subtitle Workshop
By kinghlg in forum SubtitleReplies: 6Last Post: 13th Mar 2009, 11:18
