Results 1 to 16 of 16
  1. AVStoDVD allows you to add an srt subtitle file to a project, but the project always aborts when it comes to subtitle processing. I did read in the program help file about changing the srt file from UNICODE to ANSI with windows notepad which I duly did with the same aborted outcome. There is a workround by using the bundled SubtitleCreator to convert the srt file to a sup file and load that instead and the project then completes. Just wondered if anyone has had success with srt files?
  2. Are you meaning that if you run SubtitleCreator and load your srt file, loading is fine and you can save it to sup? That's exactly what AVStoDVD does at runtime, so there's something I'm missing.
    Can you upload or send me by email (avstodvd@gmail.com) the srt file?
    Bye
    MrC
    AVStoDVD Homepage
  3. Hi MrC, thanks for the reply. I have attached the *srt file and included the log below. Nice piece of software by the way, I have been away from video for a while but was a big fan of DVD2SVCD using CCE as the encoder.
    <27/10/2010 20:35:23>
    START PROCESS
    PROJECT SETTINGS
    DVD Video Standard: PAL
    DVD Titles number: 1
    DVD Size: 4450/4450 MB (100%)
    DVD Output Setup: DVD Folder
    DVD Label: DVD
    DVD Menu: No Menu
    Output Folder: C:\Users\Clare\Desktop\Movie
    Delete Temp Process Files: No
    Delete Working Files: No
    Edit Command Parameters: No
    Post Process Task: Show Progress Status window
    PREFERENCES
    MultiThread: 1
    AVS Source Filter: A2DSource
    AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
    Video Resolution: 0
    Video BitRate Min: 2500
    Video BitRate Level 1: 8500
    Video Profile Level 2: 8500
    Video BitRate Max: 8500
    Keep DVD Compliant Video: 1
    AC3 Audio Encoder: 0
    PAL SpeedUp: 0
    Force FFmpeg for Long Audio: 1
    DVD Audio Format: 0
    DVD Audio BitRate: 224
    Keep DVD Compliant Audio: 1
    Normalize Audio: 0
    DVD Audio Language: EN - English
    DVD Subs Language: EN - English
    DVD Subs Font: Tahoma 18pt Bold
    Chapters Interval: 5
    Use Source Chapters: 1
    DVD Burning Drive: E: TSSTcorp CDDVDW TS-L633C SC01
    DVD Burning Speed: 4x
    Auto Erase DVD RW: 1
    Save Log file: 1
    Save General Settings: 0
    Unload ActiveMovie library: 0
    Adjust ffdshow mixer: 1
    TITLE 1 SOURCE FILES
    Video: C:\Users\Clare\Downloads\dmd-ts3.avi
    Info: XviD - 795 kbps - 624x352 - DAR 1.773 - 23.976 fps (CFR) - Progressive - 1:42:33 hours - 147533 frames
    Audio 1: C:\Users\Clare\Downloads\dmd-ts3.avi
    Info: MPEG-1 Audio layer 3 - 146 kbps - VBR - 2ch - 48000Hz - 1:42:33 hours - Internal
    Subs: C:\Users\Clare\Downloads\dmd-ts3.srt
    [MediaInfoLib - v0.7.35]
    AVISYNTH SCRIPT
    Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
    Video = A2DVideoSource("C:\Users\Clare\Downloads\dmd-ts3.avi", CacheFolder="C:\Users\Clare\Desktop\Movie", VFR=false)
    Audio = A2DAudioSource("C:\Users\Clare\Downloads\dmd-ts3.avi", CacheFolder="C:\Users\Clare\Desktop\Movie")
    Video = Video.ConvertToYV12
    #Using DGPulldown/HCenc to upsize FPS
    Video = Video.Lanczos4Resize(720,576)
    Audio = Audio.EnsureVBRMP3Sync()
    AudioDub(Video, Audio)
    START VIDEO ENCODING OPERATIONS
    Encoding Profile: HCenc VBR 1-pass
    Target Video FileSize: 4175.8 MB
    HCenc Parameters: -ini "C:\Users\Clare\Desktop\Movie\DVD_0_dmd-ts3.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Users\Clare\Desktop\Movie\DVD_0_dmd-ts3_1.avs
    *AVSRELOAD
    *OUTFILE C:\Users\Clare\Desktop\Movie\DVD_0_dmd-ts3.m2v
    *LOGFILE C:\Users\Clare\Desktop\Movie\DVD_0_dmd-ts3.HCenc.log
    *MAXBITRATE 9000
    *1PASS
    *BITRATE 5693
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *TFF
    *BIAS 60
    *DC_PREC 9
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 1
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <27/10/2010 21:35:02>
    END VIDEO ENCODING OPERATIONS
    A2DVideoSource: DirectShowSource
    Created File: C:\Users\Clare\Desktop\Movie\DVD_0_dmd-ts3.m2v (4178.5 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 5742 kbps - 720x576 - DAR 1.778 - 23.976 fps (CFR) - Progressive (TFF) - 1:42:27 hours - 147384 frames
    START PULLDOWN OPERATIONS
    DGPulldown Parameters: "C:\Users\Clare\Desktop\Movie\DVD_0_dmd-ts3.m2v" -srcfps 23.976 -destfps 25 -inplace -tff
    <27/10/2010 21:40:32>
    END PULLDOWN OPERATIONS
    DGPulldown executed on File: C:\Users\Clare\Desktop\Movie\DVD_0_dmd-ts3.m2v (4178.5 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 5737 kbps - 720x576 - DAR 1.778 - 24 fps (CFR) - Progressive (2:2:2:2:2:2:2:2:2:2:2:3 Pulldown) - 1:42:33 hours - 147679 frames
    START AUDIO ENCODING OPERATIONS (Track 1)
    Wavi+Aften Parameters: "C:\Users\Clare\Desktop\Movie\DVD_0_dmd-ts3_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 224 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\Clare\Desktop\Movie\DVD_0_dmd-ts3_1.ac3"
    <27/10/2010 21:42:14>
    END AUDIO ENCODING OPERATIONS (Track 1)
    A2DAudioSource: DirectShowSource
    Created File: C:\Users\Clare\Desktop\Movie\DVD_0_dmd-ts3_1.ac3 (164.3 MB)
    OUTPUT AUDIO INFO: AC3 - 224 kbps - CBR - 2ch - 48000Hz - 16bit - 1:42:33 hours
    <27/10/2010 21:42:16>
    START SUBS ENCODING OPERATIONS
    SubtitleCreator Parameters: "C:\Users\Clare\Desktop\Movie\DVD_0_dmd-ts3.srt" -p2 -i"C:\Program Files\AVStoDVD\SubtitleCreator\Examples\VTS_01_1.I FO"
    <27/10/2010 21:58:48>
    PROCESS ABORTED DURING TITLE 1 SUBS ENCODING OPERATIONS.
    CHECK LOG FILE <C:\USERS\CLARE\DESKTOP\MOVIE\DVD_0.LOG> FOR MORE INFO.
    Log file created by AVStoDVD Release 2.3.2
  4. Hi adyf,
    the attached srt file is formatted as "UCS-2 little endian" and SubtitleCreator cannot read (and convert) it.
    If you convert your srt (use Notepad++) to ANSI, then SubtitleCreator/AVStoDVD will work. Personally tested with success.
    Bye
    MrC
    AVStoDVD Homepage
  5. I was going to try again, but now have another error within HCenc:
    'can't load avisynth create script environment'
    Since I last used AVStoDVD I have installed a divx and xvid codec to use with DVD2SVCD. That wouldn't cause an issue would it?
  6. Sorted the avisynth issue by re-installing it. I still have the subtitle problem even after opening it in notepad and saving as an ANSI *srt. What did you use to determine the format of the attached *srt? Is there something other than notepad that I could try. Strange thing is that SubtitleCreator can open it.
    What would be a nice touch to the program would be the ability to resume the project from where the subtitle processing failed or any other failed process, rather than having to start from the beginning again. Would this be possible?
  7. Originally Posted by adyf View Post
    Do use Notepad++, a must in every win system. Let me know.
    It is already possible, even it is a sort of easter egg: if you delete the log file (i.e. DVD_0.log) but keep the elementary streams (i.e. DVD_0_Title01.m2v, DVD_0_Title01.ac3) then AVStoDVD will ask you if you want to keep or overwrite them. Of course you must use same DVD label and titles names.
    Bye
    MrC
    AVStoDVD Homepage
  8. Thanks for the tip for resuming projects. I see what you mean now with regard to Notepad ++, I was using Windows Notepad. I don't know why but I still have the same issue. Please would you take a look at the attached *srt that I have converted to ANSI with Notepad ++.
  9. The attached srt file is correctly formatted to ANSI and it works both at runtime and with SubtitleCreator alone.
    Do you have the possibility to check on another system?
    Bye
    MrC
    AVStoDVD Homepage
  10. Hi MrC,
    Interesting, I tried on another system with the same result. Both systems are running Windows 7 (one is Ultimate, the other is Home Premium). As per your bundled help files for Windows 7, both systems have ffdshow installed. I can get by this by manually converting *srt to *sup and loading the *sup subtitle into the project. It's just strange why it won't do this automatically.
  11. Let me try with Windows 7 as well. I will report back ASAP.
    Bye
    MrC
    AVStoDVD Homepage
  12. Hi adyf,
    just tried on a Windows 7 Home Premium system: everything run fine.
    Really don't know how to find other hints...
    Bye
    MrC
    AVStoDVD Homepage
  13. Hi MrC,
    Would you try something for me please? Set all four folders (three on paths tab and one on the opening GUI) that files are saved in to the exact same one, then encode an *avi with an *srt file. Do you get an error on subs encoding? I think I'm onto something because I restored default preferences (four different folder paths) and it worked fine. I like to use just the one folder then it's easy to delete all unwanted files at the end of processing.
  14. You have hit the point! There's a quite silly bug (delete sup file before authoring from the temp folder) to be fixed.
    Thanks for the report!
    BTW, AVStoDVD should not leave unwanted files in temp folder. It can happen only if there is an unexpected abort.
    Bye
    MrC
    AVStoDVD Homepage
  15. Hi MrC,
    Glad we got there in the end. Is this something you could fix for the next release?
  16. Originally Posted by adyf View Post
    Hi MrC,
    Yes, of course it will.
    Bye
    MrC
    AVStoDVD Homepage
