Hi -
I used to have the full Nero which I used to burn AVI files to blank dvds as a data file disc in the ISO format. I don't mean .iso files, I mean the format fo the file system on the disc. In full Nero you could choose Data-ISO or DATA-UDF for a data disc.
I allways used Data-ISO because I thought that was the standard way to do it and the discs played on all my dvd standalone players.
Discs burned in UDF file format only play on a couple of my standalone dvd players, which is a problem for me.
I don't have the full Nero anymore so I have tried a couple basic free alternatives. The free version of Nero (Nero Burnlite 10) and it does not even seem to offer the possibility of burning dvdrs the way I want them - they are always UDF. BurAware Free has something called "UDF-ISO Bridge" format that I can select. Is that the same as the old standby DVD-ISO in fill Nero? If not can anyone recommend a free burning software that does made regular ISO dvdrs?
Thanks!
File structure of UDF-ISO image files
By Waly in forum ProgrammingReplies: 5Last Post: 21st Oct 2010, 10:44 -
The right software? (dvd burning/movies/data)
By Sm12 in forum Newbie / General discussionsReplies: 1Last Post: 12th Mar 2010, 20:45 -
What burning software records a data DVD from playlists?
By Stealth3si in forum Newbie / General discussionsReplies: 0Last Post: 13th Jan 2010, 00:43 -
How can I salvage ISO with invalid UDF File Syetem?
By V Bot in forum Video ConversionReplies: 1Last Post: 10th Jan 2010, 21:37 -
UDF or ISO when burning a multi DivX DVD-R
By perceptionist in forum DVD RippingReplies: 3Last Post: 4th Jun 2007, 14:10
