hi experts!
I have a samsung hr757, but i'm tired of its lack of features. i can't record to a dvdrw disc and its very slow when it comes to recognizing a usb stick and it's very bad at playing all sorts of burnt discs. Also I would like one,if possible, where you can save your recording straight to a usb stick.
Any suggestions, any player you would recommend?
Nille
It would be good to tell us where you live because if you live in the UK (as I suspect because you said "burnt"), recommendations involving American DVD recorders aren't going to be very useful to you, are they? Similarly recommendations on UK recorders would be useless to someone in the USA or Canada.
It would be good to also explain what you mean by "save your recording straight to a USB stick". Do you mean record directly to a USB device? Or do you mean record to an internal hard drive and then copy that to a USB device? And if you need an internal hard drive, that would be good to know also. -
Hi again!
I understand that I need to clarify a few things. I live in Sweden and when it comes to the USB-stick I meant recording to an internal hard drive and the transfer the recording to a USB-stick, which I'm not able to do now.
Thanks for your help
Nille
Looking for advice on buying a new DVD recorder
By luvsufo in forum DVD & Blu-ray RecordersReplies: 4Last Post: 16th Feb 2011, 16:10 -
After a new DVD recorder but need advice....
By TheGMan in forum DVD & Blu-ray RecordersReplies: 5Last Post: 13th Jun 2008, 19:16 -
advice for a new dvd recorder
By cd090580 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 25th Feb 2008, 18:44 -
Need advice on new DVD Recorder.
By MeekloBraca in forum DVD & Blu-ray RecordersReplies: 5Last Post: 15th Aug 2007, 10:28 -
Advice on a new DVD recorder
By JakeAy in forum DVD & Blu-ray RecordersReplies: 3Last Post: 2nd Aug 2007, 23:23
