Hi
I'm trying to convert an mp4 file into a DVDR and introduce subs on it.
I'm using WinAVI v10.1 to convert the mp4 file in VOB. The original aspect R for the video is 16:9 720p. I want to keep this resolution or similar. After convertion everything is fine and the VOB files are working properly in my DVD player.
I make an ISO image of the DVD and start using DVD Decrypter to demux the video and audio files.
After this I load the demuxed files to DVDLab Pro v2.51 so I can add the subtitle.
When I hit COMPILE DVD I get the following error:
"The Read data size is over the buffer limit"
This makes the compiling to stop.
I have tried many different settings in converting the mp4 file to VOB.
I believe that's where the problem starts since I have been using this method (DVD Decrypter + DVDLab) for a long time and it never happened before.
The demuxed M2V file that I get with DVD Decrypter after the whole process before I start working in DVDlab is usually higher than 2000 kbps.
Anyway, it's important to mention that I used to do this procedure with a Core 2 Duo @ 3.80 Mhz / 4 GB DDR2 and now I'm using a Core 2 Duo @ 1.68 Mhz / 768 MB DDR2 so it might be a memory problem as well.
TY in advance for Ur support
Results 1 to 1 of 1
MPEG Streamclip "limit data rate" disabled
By Dignan. in forum Video ConversionReplies: 7Last Post: 23rd Nov 2011, 12:59 -
DVD-lab PRO v1.6 - "Map" only gives the color black
By Paker in forum Authoring (DVD)Replies: 1Last Post: 3rd Sep 2009, 13:30 -
DVD Pro Lab - Error: Read Data Size
By lapetite_66 in forum Authoring (DVD)Replies: 2Last Post: 23rd Jul 2009, 14:48 -
DVD Lab Pro - Three elemenetary "hot to ....." questions
By perfection in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2007, 06:45 -
[ERR] GOP size is over the buffer limit - Compiling in DVD-lab PRO 2.30
By Wolverene in forum Authoring (DVD)Replies: 7Last Post: 31st Aug 2007, 22:55
