I just bought an HDTV and got the HD box from my cable provider. The problem I am having is FOX HD and a few other HD stations aren't stable, they keep blacking out and losing the picture. Interestingly enough ABC, NBC, CBS, PBS, and most other HD channels are stable with a good picture quality.
I tried disconnecting the HD box and just using the cable but the problem persists.
Does anyone have an idea of what could be happening here, is this a signal problem in the house?
On a side note we have been having severe wind problems in the area I live in. I checked the stations today and there isn't any wind to speak of and the problem remains the same.
The majority of the HD stations work great it is just a couple of them that are intermittent.
Any help or information would be greatly appreciated.
Thanks...
Results 1 to 12 of 12
It could be a problem with the cables in the house, the splitters or the level or equalization coming in from the amp on the pole outside. The splitters should all be labled 1000 MHz (1 GHz) or more.
There is no direct relationship between the virtual channel numbers on the box to the actual cable channel but HD is often placed on the higher frequencies >600 MHz. These are most subject to equalization issues.
Try this first. Run the cable coming into the house directly to the HDTV box with no splitters. If the problem shows here it tends to indicate a cable company problem. They may not charge for a service call if you can show a problem as the signal enters the house.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks for the help! The cable that comes in from the outside only has enough cable to run to the splitter which is in our basement. I am not sure what to do here.
If the splitter was bad wouldn't I be having problems with my Internet? It is a 3-way splitter?Last edited by crowheart; 28th Oct 2010 at 15:18.
You can bypass the splitter and use a 1 to 1 coax coupler for the test. Main issue is not to have multiple splitters in series.
Otherwise, talk to their service line and/or order a service visit. If it is just two channels, they will know if those are in the highest frequencies. I suspect they will just need to make equalization adjustments in the amp feeding your house.Recommends: Kiva.org - Loans that change lives.
First make sure the splitter is labled 1 GHz or more. If you've never had HD service at this address, the splitter may be very old. New ones only cost $5 or so. If you order a service visit, they will probably replace the splitter for free.
Internet is usually carried in lower channels. They tend to push the higher channels (frequencies) with HD service.Recommends: Kiva.org - Loans that change lives.
Thanks so much for you help. I will try that and see if it works. After further investigation I do see that the cable company did not put in new coax; they used the existing coax to run from the splitter to the TV. This was done at least 5-years ago. The cable was in place and used for antenna reception since probably long before we bought the house which was 11 years ago.
The existing coax is quite old, possibly this is the problem, but if it was wouldn't it affect all of the HD channels?Last edited by crowheart; 28th Oct 2010 at 15:44.
Possible but not likely. If this is RG6 (the good stuff) it is probably OK although a connector may be bad. If RG59, it was probably a user or house builder install and more suspect.
Still the problem is most likely outside the house.
If the cable guy comes out, the first thing he does is put a spectrum analyzer on the incoming cable to see if the signal is OK coming in. He may do this at the pole. Then he starts the "taxi meter" to correct in-house issues.Last edited by edDV; 28th Oct 2010 at 15:54.
Update! It wasn't the good stuff (RG6). It was the RG59 that was the problem.The cable from the splitter to the TV was RG59! When we originally got the cable they used the existing coax to hook up to the analog TV (Sloppy/lazy). All the HD channels work fine now.
You guessed it right. thanks... -
A Tech from the cable company came out and tested everything. The problem was the RG59 we replaced and the HDTV is working great!
Thanks again... -
On the Scientific Atlanta boxes...
Press SELECT until the light starts blinking
Press the INFO button until the service screen comes up
Press the VOLUME+ button until you reach page 5
Under Current FDC look for
Level: -6dBmV
The acceptable range is from -11dBmV to +11dBmV. The closer to 0dBmV the better.
Changing splitters and cables will affect these numbers.
Bad signal between recorder & TV
By Ken Clark in forum Newbie / General discussionsReplies: 0Last Post: 30th Apr 2012, 04:08 -
converting bad laser Sony DVD players into Test Pattern Signal Generators?
By turnkit in forum DVD & Blu-ray PlayersReplies: 5Last Post: 10th Jan 2012, 02:46 -
Bad mixture of video signal adapters?
By Silent Nick in forum Newbie / General discussionsReplies: 2Last Post: 14th Mar 2010, 02:57 -
Direct TV/HDTV Signal Question
By RKelly in forum DVB / IPTVReplies: 5Last Post: 12th Mar 2010, 00:55 -
Does CW do something to their HDTV signal?
By mattman1968 in forum DVB / IPTVReplies: 3Last Post: 9th Jun 2008, 08:21
