Hello,
I am looking to covert some tapes from a MiniDv cam and looking at the possibility of a direct capture to something like a portable dvr or something like it that would capture directly to a mp4 or something similar that I could transfer directly to a pc. Anyone have any suggestions. Any help is appreciated.
Thanks in advance.
you could use a firewire port and capture direct to the computer. if you don't have a firewire port add-in cards are available fairly cheap.
Direct capture to MPeg4 will lower quality. Is that OK? What is the target device? An iPod?
What is your budget for this portable device?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
edDV: Lower quality is ok. Target device will to be played on pc's, laptops, etc. Budget wise I don't won't to get too crazy, not more that a few hundred would be nice. Thanks.
MiniDv Capture Advice
By afoote@acslink.net.a in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 13th Nov 2008, 07:22 -
Need Capture Device recommendation advice!
By unclekracker in forum Capturing and VCRReplies: 4Last Post: 2nd Apr 2008, 12:54 -
Can someone direct me to a good capture device..
By KameronK in forum Capturing and VCRReplies: 5Last Post: 28th Mar 2008, 22:46 -
Do I need a firewire card to capture video from my miniDV device?
By MPTESE in forum Capturing and VCRReplies: 8Last Post: 16th Mar 2008, 09:55 -
Advice: Capture via Matrox RT.X2, EDIUS NX Express, or Composite on DV cam?
By Riker0007 in forum Capturing and VCRReplies: 1Last Post: 11th Jul 2007, 16:30
