Under "Track playback and action setting" "Display the track menu" is a option. Every time a chapter finishes I want it to display the track menu not play the next track. I think I had this problem before but do not remember what I did. Is this not possible with TMPGEnc DVD Author or am I doing something wrong.
	menu wizard -
 display track 1 menu-
 display the track menu-
 might get you there.;/ l ,[____], Its a Jeep thing,
 l---L---o||||||o- you wouldn't understand.
 (.)_) (.)_)-----)_) "Only In A Jeep"
	I miss spoke. Every time a chapter finishes I want it to display the track menu no play the next chapter.
 Track 1 has several clips(chapters) in it. When one clip(chapter) finishes I want it to display all the clips(chapters) in that track not play the next clip(chapter).
	As Alex_ander said, TDA won't do it with chapters. Using one of the editors he mentionned, you can modify the navigation commands to force a return to the menu after playing a chapter. This is fairly complicated and you better know what you're doing or you'll have to spend some time troubleshooting your edits.
 He also said TDA will work the way you want if your clips are tracks. This is probably what you did before to get it to work. Using the same source, redo your layout and add each clip as a separate track. Set the action after playback to "return to main menu" and create "main menu only". You will get a menu with all the tracks (clips) listed. You might get multiple pages depending on the munber of tracks to display and the number of tracks per page you selected i.e. if you want everything on 1 page and you have 12 clips, choose a custom layout that will show at least 12 items.
  'MP4 has no usable track' yet plays in VLC Media PlayerBy JuliaR in forum Newbie / General discussionsReplies: 6Last Post: 10th Mar 2012, 18:57
  why do some dvds not allow elapsed time/chapter to display?By spiritgumm in forum Newbie / General discussionsReplies: 0Last Post: 9th Feb 2011, 11:27
  Roxio MyDVD menu displayBy moviegeek71 in forum Authoring (DVD)Replies: 1Last Post: 15th Oct 2008, 22:03
  VLC problem - doesn't display full length, only plays bits...By MikeMGMVE in forum Software PlayingReplies: 3Last Post: 3rd Sep 2008, 15:38
  DVD Menu with Chapter and Menu Template.By big-boo in forum Authoring (DVD)Replies: 3Last Post: 17th Mar 2008, 07:20
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
