  1. I used to be able to get it to run just about anything with directshowsource.
    My computer was having problems playing audio with some new videos, so I updated CCCP. I completely forgot that the version of ffdshow that's packaged in with this is incomplete.
    Now I can only get VDM to work with AVIs. It crashes with anything else, including files that it worked with prior to the update.
    I uninstalled CCCP, installed the full version of ffdshow, and reinstalled CCCP with the ffdshow box left unchecked. Then I went into video configuration, VFW configuration, and audio configuration and set all of the codecs in the codecs section on. (either to libavcodec or the first option available)
    VDM still crashes.
    This is how I remember fixing it last time, but I'm obviously forgetting something. Google doesn't turn up quick results, either.
    MPC-HC is working fine, BTW.
    Mar 2008
    Do you really need CCCP? How about just FFDshow and Haali splitter ?
  3. I don't think that getting rid of CCCP will fix my problem.
    I don't see a Haali Media Splitter tab in my start menu, so I probably never installed it separately the first time.
    Edit:
    I looked at my old posts. I had an error back then. VDM didn't crash like it does now. Could CCCP have deleted a codec?
