So I have myself a Hi8 VCR that I got a little while ago. It is a Sony EV-S900. There are a bunch on ebay if you want to see what they look like, http://shop.ebay.com/i.html?_nkw=ev-s900&_sacat=0&_odkw=evs900&_osacat=0&_trksid=p3286 .c0.m270.l1313
Anyway, when I plug it it, it starts up, I can feed input into it, etc, the only problem is, I cant seem to open the tape tray. Yep, this deck has a tape tray (Like a DVD tray) instead of a flap like most decks do. Of course, there is an 'Open/Close' button right next to it, but this seems to do nothing when the unit is turned. If the unit is off, this button will turn on the unit when pressed, so I don't think the button is broken. There is also no movement coming from an mechanisms in the deck as well. So I would think if the tray was jammed it would try at least try to eject and then stop instead of the situation I have.
So I'm wondering if there are any people who might have been around when these were at their peak and have had experience with a tray-loading machine. Maybe I have to switch into some strange setting I cant find?
You might want to email this guy and ask his opinion.
http://cgi.ebay.com/REPAIR-SERVICE-SONY-8mm-EV-S900-VCR-/190459948154?pt=LH_DefaultDom...item2c584c2c7aRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 00:54 -
Should I capture VCR, 8mm and Hi8 tapes to MPEG2 or MPEG4?
By dorenhagen in forum Capturing and VCRReplies: 18Last Post: 25th Jan 2011, 22:00 -
Sony Hi8 has been defective but want to play the Hi8 tape
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 22nd May 2009, 22:06 -
Hi8 vcr, better playback than a Hi8 camcorder?
By Knightmessenger in forum Capturing and VCRReplies: 8Last Post: 22nd Dec 2007, 01:11 -
Will cheap new Hi8 camcorder output better than old, worn Hi8 camcorder?
By ErikL7 in forum RestorationReplies: 7Last Post: 2nd Sep 2007, 06:26
