I have ripped 2 bluray's to my harddrive using the backup function of Makemkv and i have then ripped the films to mkv, but i am now trying to rip the subtitles for the foreign parts of the film using HDBR stream extractor but its not working and i think there is still protection on them, so i am looking for something that might allow me to get rid of the protection or another program that can rip the subs also the backup films dont playback either i have tried bluray region code remover but it didn't work.
Thanks in advance for any help
I have two questions:
1) Can MakeMKV rip to hard drive *without* converting to MKV? New feature? I haven't used it in a while.
2) Title of the movie?
And I have a suggestion: Use DVDFabPasskey (free while it's beta) in the background to decrypt in conjunction with Clown_BD, as Baldrick says. Never failed yet for me, whatever stream I tried to extract. OTOH, and this may no longer apply, but MakeMKV always screwed the subs for me somehow. Couldn't extract them, and couldn't display them in MPCHC. So your problem seems suspiciously like what I experienced. I confess I only used MakeMKV maybe a dozen times, but there you are. Try another method to confirm whether the problem is or is not MakeMKV.Pull! Bang! Darn! -
tried this but it didn't work
fritzi93Re: Need Help With Ripped Bluray
Yes make mkv has a backup option, so you can backup full disk.
The movies are godzilla and the mummy
I think your right it might be an makemkv problem but i think it need to try some more programs than can extract subtitles, so if you have any ideas of good sub extraction programs please let me know, or is there an easy to use site that i can download subtitles from
How to open ripped bluray in powerdvd 12?
By mason dixon in forum Blu-ray RippingReplies: 1Last Post: 1st Mar 2012, 12:26 -
Have you ripped your dvd/bluray collections for use with your wdtv etc?
By yoda313 in forum Newbie / General discussionsReplies: 7Last Post: 6th Aug 2011, 23:29 -
ripped bluray to TS
By nirbhayn in forum Video ConversionReplies: 1Last Post: 26th Jul 2010, 22:38 -
burning ripped bluray?
By tomrip in forum Blu-ray RippingReplies: 3Last Post: 14th Feb 2009, 22:32 -
Are you able to author ripped bluray as hddvd and viceversa?
By yoda313 in forum Newbie / General discussionsReplies: 3Last Post: 10th Nov 2007, 21:04
