    Oct 2010
    Surrey,England
    i want to play my mp4 files on my P.C but will not play on windows media player
    thank you
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    VLC
    Feb 2008
    Twin Peaks
    I use either quicktime, or divx player
  4. Member PuzZLeR's Avatar
    Oct 2006
    Toronto Canada
    Keep in mind, MP4 is only a container, it's what's in it that counts.
    Nevertheless, I too say VLC (although QuickTime and DivX Player have improved much over the last few years.)
    But if you do want to play the MP4 files on WMP, depending what's in them, then you should install ffdshow (or look into CCPC). Avoid installing any of those codec packs as my recommendation (such as K-Lite) - very bad.
    Note: If you want mimimal installations, without having to install all those codecs, decoders, external software, Apple stuff, etc, just stick with one app, VLC, since it runs on its own internal decoders.
    I hate VHS. I always did.
