I have been experimenting with different TV tuners and broadcasting options that I currently have access to.
Asus MyCinema EHC3150 so far I have had great results with this Card for TV but when I started streaming to veetle or any other streaming sites applications my input size is very small 352X288 that is it no secondary options now obviously when I broadcast that as soon as you start to enlarge the output the distortion gets out of control fast. I wasn't sure what was causing this if it was software related or hardware related so I purchased another TV Tuner locally. This time I purchased the PCTV 800i much to my surprise input size was larger 720X480 this does allow me a larger picture with a higher quality stream.
Now what I'm really trying to figure out is how can I find out the max input size for a TV Tuner before purchasing it? Does anyone have a TV Tuner suggestion that provides a larger option of input sizes? Or does anyone know how I can find out what input sizes will be available without buying cards and sending them back as they don't offer anything better then I currently have?
Results 1 to 1 of 1
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 11:46 -
How to set streaming audio input to Audacity?
By edDV in forum MacReplies: 2Last Post: 25th Aug 2008, 13:19 -
Is There a Practical File Size Limit For Streaming FLV?
By phild in forum Newbie / General discussionsReplies: 1Last Post: 18th Aug 2008, 09:13 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 08:59 -
Input video size problem with AVI ReComp
By 4194 in forum DVD RippingReplies: 0Last Post: 26th Aug 2007, 13:43
