Does anyone know if there are compatibility issues between Corel's VideoStudio Pro X3 software and ATI's TV Tuner Pro 650 Video card? The Pro X3 program won't recognize the card, but my Roxio Media Creator 10 program recognizes it fine. However, I prefer to capture through VideoStudio. Should I get a different/better/newer capture card?
Dell XPS Gen 2 Desktop
Windows 7
Capture thru Roxio at the highest possible quality settings and then export your project to X3. Voila, money saved, no new hardware required, gtd compatibility. Check for new drivers, software updates possibly update to Win/xp win/?7
The electronic components of the power part adopted a lot of Rubycons.
Anyone familiar with Corel VideoStudio Pro X2?
By brassplyer in forum EditingReplies: 5Last Post: 23rd May 2010, 11:00 -
Widescreen Output Using ATI Theater 650 Pro and Ulead VideoStudio X2
By waldodiodio in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2009, 11:00 -
Opinions on Corel VideoStudio X2 Pro
By Smack2k in forum Capturing and VCRReplies: 4Last Post: 12th Jul 2009, 00:32 -
Is Corel VideoStudio Pro X2 really worse than Vegas Movie Studio 9 ?!?
By vantechmag in forum EditingReplies: 2Last Post: 11th May 2009, 13:03 -
Corel VideoStudio Pro X2 effects
By fayt in forum Newbie / General discussionsReplies: 8Last Post: 25th Feb 2009, 12:18
