AVC2AVI Revision 594 (including GUI ver. 1.2) if i convert h264 file larger than 1.5gb to avi, vdub tries to convert file using its aviimport mode but simply stops at about 1.5gb file open, i tried to fix using manual select open options ask vdub to recalculate keyframes it takes much longer to open still stops at about 1.5gb, to fix this i downloaded avc2avi mod, which came nice simple text of dos command options, i used avc2avi mod to convert the file to segments less than 1gb(avc2avi -f 23.976 -s 995 -i x.h264 -o x.avi), then i opened first avi file segment with vdub(+ffdshow as my codec) appended the other 2 segments and added the audio that i had saved seperately and did direct save single file output it worked perfectly and audio was perfect in sync
please fix AVC2AVI GUI to include segments section, i recommend it should be set default to 1gb max
Results 1 to 1 of 1
avc2avi gives bad avi file...
By zovx in forum Video ConversionReplies: 2Last Post: 8th Mar 2010, 21:32 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Bad sound quality from avi's to DVD w/both Toast or XiliSoft DVD Creator?
By NoMoPackers in forum MacReplies: 7Last Post: 2nd Apr 2009, 04:57 -
Background picture looks bad DVD authored with GUI for dvdauthor
By stars in forum Authoring (DVD)Replies: 10Last Post: 10th Feb 2009, 04:32 -
avc2avi gui
By Shaorin in forum Newbie / General discussionsReplies: 3Last Post: 11th Jul 2008, 19:43
