i have a sony 25g BD-RE which i use to test my backups on before finaly burning to a BD-R, i have been using image burn and put a movie onto this BD-RE and it will no longer play in my PS3 yet the information still shows up on the disc on my PC.
i have even reformatted the disc as a UDF 2.50. i have also used nero, its like the disc isnt finalising even though the programs have these ticked to do so.
any help on this would be great.
Results 1 to 9 of 9
post the full logfile
*** Now that you have read me, do some other things. *** -
sorry for sounding dumb do you mean this log file right after i have done a burn.
I 08:37:49 ImgBurn Version 2.5.2.0 started!
I 08:37:49 Microsoft Windows 7 Ultimate Edition (6.1, Build 7600)
I 08:37:49 Total Physical Memory: 2,094,904 KB - Available: 641,528 KB
W 08:37:49 AnyDVD can interfere with ImgBurn's ability to verify accurately, please ensure it's disabled!
I 08:37:49 Initialising SPTI...
I 08:37:49 Searching for SCSI / ATAPI devices...
I 08:37:49 -> Drive 1 - Info: HL-DT-ST BD-RE BH10LS30 1.00 (F
(ATA)
I 08:37:49 Found 1 BD-RE!
I 08:52:42 Operation Started!
I 08:52:42 Building Image Tree...
I 08:52:42 Calculating Totals...
I 08:52:42 Preparing Image...
I 08:52:43 Contents: 9 Files, 14 Folders
I 08:52:43 Content Type: BD Video
I 08:52:43 Data Type: MODE1/2048
I 08:52:43 File System(s): UDF (2.50)
I 08:52:43 Volume Label: [Not Configured]
I 08:52:43 Size: 24,319,824,892 bytes
I 08:52:43 Sectors: 11,874,921
I 08:52:43 Image Size: 24,320,868,352 bytes
I 08:52:43 Image Sectors: 11,875,424
I 08:52:43 Operation Successfully Completed! - Duration: 00:00:00
I 08:54:10 Operation Started!
I 08:54:10 Building Image Tree...
I 08:54:10 Calculating Totals...
I 08:54:10 Preparing Image...
I 08:54:10 Contents: 9 Files, 14 Folders
I 08:54:10 Content Type: BD Video
I 08:54:10 Data Type: MODE1/2048
I 08:54:11 File System(s): UDF (2.50)
I 08:54:11 Volume Label: [Not Configured]
I 08:54:11 Size: 19,266,206,616 bytes
I 08:54:11 Sectors: 9,407,334
I 08:54:11 Image Size: 19,267,256,320 bytes
I 08:54:11 Image Sectors: 9,407,840
I 08:54:11 Operation Successfully Completed! - Duration: 00:00:00
I 08:54:35 Operation Started!
I 08:54:35 Building Image Tree...
I 08:54:37 Calculating Totals...
I 08:54:37 Preparing Image...
I 08:54:38 Contents: 9 Files, 14 Folders
I 08:54:38 Content Type: BD Video
I 08:54:38 Data Type: MODE1/2048
I 08:54:38 File System(s): UDF (2.50)
I 08:54:38 Volume Label: A & D
I 08:54:38 Size: 19,266,206,616 bytes
I 08:54:38 Sectors: 9,407,334
I 08:54:38 Image Size: 19,267,256,320 bytes
I 08:54:38 Image Sectors: 9,407,840
I 08:54:40 Operation Successfully Completed! - Duration: 00:00:05
I 08:54:40 Operation Started!
I 08:54:40 Source File: -==/\/[BUILD IMAGE]\/\==-
I 08:54:40 Source File Sectors: 9,407,840 (MODE1/2048)
I 08:54:40 Source File Size: 19,267,256,320 bytes
I 08:54:40 Source File Volume Identifier: A & D
I 08:54:40 Source File Application Identifier: ImgBurn v2.5.2.0
I 08:54:40 Source File Implementation Identifier: ImgBurn
I 08:54:40 Source File File System(s): UDF (2.50)
I 08:54:40 Destination Device: [2:1:0] HL-DT-ST BD-RE BH10LS30 1.00 (F
(ATA)
I 08:54:40 Destination Media Type: BD-RE (Disc ID: SONY-ES1-02) (Speeds: 2.4x)
I 08:54:40 Destination Media Sectors: 11,826,176
I 08:54:40 Write Mode: BD
I 08:54:40 Write Type: DAO
I 08:54:40 Write Speed: 2.4x
I 08:54:40 BD-RE FastWrite: No
I 08:54:40 Link Size: Auto
I 08:54:40 Lock Volume: Yes
I 08:54:40 Test Mode: No
I 08:54:40 OPC: No
I 08:54:40 BURN-Proof: Enabled
I 08:54:40 Write Speed Successfully Set! - Effective: 10,338 KB/s (2.4x)
I 08:54:41 Filling Buffer... (40 MB)
I 08:54:42 Writing LeadIn...
I 08:54:48 Writing Session 1 of 1... (1 Track, LBA: 0 - 9407839)
I 08:54:48 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 9407839)
I 10:01:37 Synchronising Cache...
I 10:01:38 Exporting Graph Data...
I 10:01:39 Graph Data File: C:\Users\B Mason\AppData\Roaming\ImgBurn\Graph Data Files\HL-DT-ST_BD-RE_BH10LS30_1.00_WEDNESDAY-OCTOBER-27-2010_8-54_AM_SONY-ES1-02_2.4x.ibg
I 10:01:39 Export Successfully Completed!
I 10:01:39 Operation Successfully Completed! - Duration: 01:06:58
I 10:01:39 Average Write Rate: 4,693 KB/s (1.0x) - Maximum Write Rate: 5,373 KB/s (1.2x)
I 10:01:39 Cycling Tray before Verify...
W 10:01:47 Waiting for device to become ready...
I 10:02:03 Device Ready!
I 10:02:04 Operation Started!
I 10:02:04 Source Device: [2:1:0] HL-DT-ST BD-RE BH10LS30 1.00 (F
(ATA)
I 10:02:04 Source Media Type: BD-RE (Disc ID: SONY-ES1-02) (Speeds: 2.4x)
I 10:02:04 Image File: -==/\/[BUILD IMAGE]\/\==-
I 10:02:04 Image File Sectors: 9,407,840 (MODE1/2048)
I 10:02:04 Image File Size: 19,267,256,320 bytes
I 10:02:04 Image File Volume Identifier: A & D
I 10:02:04 Image File Application Identifier: ImgBurn v2.5.2.0
I 10:02:04 Image File Implementation Identifier: ImgBurn
I 10:02:04 Image File File System(s): UDF (2.50)
I 10:02:04 Read Speed (Data/Audio): MAX / MAX
I 10:02:04 Verifying Session 1 of 1... (1 Track, LBA: 0 - 9407839)
I 10:02:04 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 9407839)
I 10:24:00 Exporting Graph Data...
I 10:24:01 Graph Data File: C:\Users\B Mason\AppData\Roaming\ImgBurn\Graph Data Files\HL-DT-ST_BD-RE_BH10LS30_1.00_WEDNESDAY-OCTOBER-27-2010_8-54_AM_SONY-ES1-02_2.4x.ibg
I 10:24:01 Export Successfully Completed!
I 10:24:01 Operation Successfully Completed! - Duration: 00:21:56
I 10:24:01 Average Verify Rate: 14,297 KB/s (3.2x) - Maximum Verify Rate: 20,094 KB/s (4.5x)Last edited by Bazza-61; 26th Oct 2010 at 23:07.
Is that correct?
" I 08:54:40 Write Speed: 2.4x"
Also, did you (fully) format the disc before the burn?*** Now that you have read me, do some other things. *** -
Hi Chef, yes i would say that is correct as i did a copy and past.
i have done a full format a few times as well as a few quick formats.
or what i should say is i used image burn to do a full erase, and ive tried a format through windows and neither worked yet it was fine the couple of time before.Last edited by Bazza-61; 29th Oct 2010 at 21:53.
Do you have another one of this media, same type, same specs, to try with?
Maybe your burner just has a problem with this specific media now because of the usage so far?!*** Now that you have read me, do some other things. *** -
You've got spare areas enabled there (can tell by the size of the disc).I 08:54:40 Destination Media Sectors: 11,826,176
Maybe the PS3 wants a disc formatted without them? -
How old is the PS3? How old is the BD-re? What make/brand is the BD-re? Just coz you paid ($$big bucks$$) for the disk dont expect it to last for ever ... I have thrown away quite a few CD/rw and DVD/rw when they went bad, it happens.
Lens cleaner, Different disc (BD/RE) should all be tried.
Has this procedure worked previously? have you installed anything new (hrd/soft) on your PC? drivers? were you eating Nachos or performing other bodily functions? (Clean hands lead to a Clean Mind leads to a Clean BUrn)
thanks guys ill turn off spare area's although that must be on as default.
my PS3 is 2years old second release was 40gig model but i put a 500gig in, the disc is 2 months old and worked fine for the first 4-5 burns played in the PS3 fine, i allways clean my disc's before use, ive tried a DVD re-writeable and that works fine so i guess it must be the disc
i was using image burn until it didnt work so i updated to latest release and that didnt work either.
so short of buying another BD-RE at $20 i could try ringing sony or try it in another machine.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
