    Oct 2010
    Santo Domingo
    If my VCR has Composite inputs and S-Video output can it really turn Composite to S-Video?
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    In most cases yes but it won't necessarily increase quality.
    All VCRs will separate composite into Y and C. This is what is recorded to tape. But the way they go about it differs.
    A cheap VCR (most all VHS models) will low pass filter composite at 3MHz and notch filter 3.58 MHz* subcarrier for C. The higher luminance frequencies are discarded. A more sophisticated S-VHS model (not all) will use a comb filter to separate Y and C. This keeps higher luminance frequencies (picture detail) out to 4.5 MHz.
    What is the model number if this VCR?
    * 4.43 MHz for PAL.
    http://www.kiva.org/about
    Aug 2006
    Well, it will be output as S-Video, in most cases, but the quality of the outgoing video still won't be as good as it would be with an S-Video source. However, if you are lucky, the incoming video will go through a comb filter that reduces the noise associated with a composite source and it will look a little better than it would otherwise.
  4. And in any case, it will not increase the resolution, remove the time base jitter, or reduce the static noise. It will only reduce dot crawl artifacts.
    Oct 2010
    Santo Domingo
    * 4.43 MHz for PAL.
    Thanks. It's LG V-881M. It's actually really old but still usable.
  6. Member edDV's Avatar
    Mar 2004
    That appears to be a VHS VCR plus DVD player combo. It probably has no comb filter on the VCR input. In many cases, these combo players only output S-Video from the DVD player. You can test this yourself. Play a tape or connect a composite source and see if video is present on the S-Video output.
