Dear All
I have philips DVP 3140 player,could you please tell me how can i copy divx format movies into DVD,I have triend to copy it through nero but its not working, please help
Regards
Khan
You just burn a data disc with the divx file. What do you mean "its not working"? Does the player give some kind of error message when you put the disc in? Does it show the filename? Do you get get an error when you try to play the file? Do you get audio and no video? Video but no audio?
Thanks for the reply,actually i have already divx format movie in my laptop hard disk, i will tell you the all steps.
-open nero and then use copy data disk option and burn.
-after burn,inserted into my DVD player.
-DVD player read the file and show the file name.
-when i play it then after taking some time,it start again and give me the file name once again.
Regards
Khan
and when i copy divx format file throgh nero by using copy data disk option -
You have MUCH reading to do. Read the manual for your player. It will tell you what type of Divx file the player likes....mostly it is the audio used in the Divx file that is most important. Then run the Divx file through GSpot and compare the player specs to the Divx file.
Common Divx/DVD player problems:
https://forum.videohelp.com/threads/295067-Common-DivX-DVD-Players-AVI-Playback-problems!
Another thing to note: Divx recently added h.264 (MPEG 4 part 10) to their original Divx/Xvid (MPEG 4 part 2) package. Your player will not play h.264 encoded video.
How to copy "DICOM" CDs to hard drive then run from hard drive?
By JohnnyBob in forum Newbie / General discussionsReplies: 1Last Post: 25th Apr 2010, 17:18 -
HELP Please - Best Program for DVD to DivX/Xvid to run on 64bit win7
By Jorocketoz in forum DVD RippingReplies: 7Last Post: 4th Feb 2010, 05:39 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 07:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
LG lh-rh361se: How to copy divx to DVD?
By picchew in forum DVD & Blu-ray RecordersReplies: 3Last Post: 9th May 2007, 06:57
