Hi. When i insert a media in the timeline, i only get three preview thumbs. One at the beginning, one in the middle and one at the end. How can i change that so i get preview thumbs all the way along the timeline?
Using Sony Vegas Studio Platinum 10.
Would greatly appreciate some help!
In the pro version it's options=> preferences=> video => thumbnails => all . Not sure about the studio version
I changed your title to match your subject. You may get more answers that way.
Moderator redwudz -
FYI, when you generate all the frames, you take a performance hit, and to get down to the frame level makes you scrub the timeline, so you might as well just keep it heads,middle,tail and scrub the preview window instead, then drill down to the section you want to edit.
Thanks for the help people
I'll try to find the setting there, but i think i've looked there allready, couldnt find anything in the help-files about thumbnails either..
I've just got mye work-computer upgraded severly, so i hope it will be up for some quick frame-processing. -
hey, i did what you said "poisondeathray", and i found it! thank you again for the help everyone.
Does Sony Vegas Movie Studio HD Platinum 10 do 60fps?
By vid83 in forum EditingReplies: 13Last Post: 7th Feb 2011, 19:33 -
Is Sony Vegas Movie Studio HD Platinum 10 a good editing software?
By vid83 in forum EditingReplies: 8Last Post: 4th Feb 2011, 08:02 -
Sony Vegas Platinum 9.0 & Architech Studio 4.5
By bpinto0805 in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2009, 20:02 -
Sony Vegas Studio 8 Platinum Wipes
By luigi2000 in forum EditingReplies: 2Last Post: 30th Aug 2008, 15:46 -
SONY Vegas Movie Studio Platinum 8.0
By pcanaveral in forum EditingReplies: 4Last Post: 13th Oct 2007, 23:38
