I've been without success been trying to author HD-DVD's. I tried to author a SD DVD to HD-DVD. I used the French movie "Crimson Rivers" because it's only 3.5GBs. It worked but only after one failure. Movie Factory gives you two options when you select HD-DVD,standard and advanced. Standard creates a 3x disk that will not play on my HD-DVD players,but advanced creates a traditional HD-DVD structure and these will play on my HD-DVD players when burned on a DVD-R.
Not trying to offend, but what is the point of this post?
And then you tell us how you did get it to work using the Advanced setting. Are you just trying to tell people what did and did not work for you? Do you need help with some problem that you failed to mention?
Given the lack of interest in this dead format, I'm not sure that telling people what you did is of much use. I used to make HD DVDs myself a couple of years ago using both Movie Factory and Scenarist and I far preferred to use Scenarist for the task. I'm not really seeing how it is practical to still be talking about this subject.
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 09:48 -
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 13:22 -
Ulead DVD Movie Factory...
By mmitchell_houston in forum Authoring (VCD/SVCD)Replies: 225Last Post: 23rd Oct 2007, 11:59 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 08:14 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 19:20
