I know it's an old version of Vegas, but please bear with me:
I started editing a new project in Vegas Movie Studio Platinum Edition 7.0a that included some public domain footage from archive.org.
The audio came in OK. Video came in like a psychedelic "posterize" effect-- the color pallete was shifted so you could only make out shapes and motion but there was a weird mixture of colors. Every other frame is black.
I thought it was a problem with the source media file, so I opened an old project to check. I found the same problem in all MPEG4 media (example of one here: http://www.archive.org/details/hazards_of_helen_wild_engine).
That old project included some media that came from my miniDV camcorder (AVI) alongside the MPEG4 file above. All the camcorder footage looks fine and other Vegas functionality is OK.
No CPU hardware changes have been made since this last worked (though I did get a new LCD monitor to replace a CRT), and no major software changes (just Windows & Antivirus updates).
I tried removing Vegas, deleting all its registry and Application Data, and reinstalling but it didn't help.
The file above is H.264 encoded, and plays OK in QuickTime.
Any idea why my system lost the ability to process these files?
Try installing xvid codec
https://www.videohelp.com/tools/XviD_Codec
EDIT: I didn't see your edit. If it's h.264, then installing xvid won't help you. (I assumed MPEG-4ASP when you said "MPEG4")
Did you upgrade quicktime recently ? If so, downgrade to an older version like 7.4.X , many vegas users have had problems with the recent quicktime versionsLast edited by poisondeathray; 25th Oct 2010 at 11:28.
Corel Video Studio Pro x4 has stopped working?
By TheKillerQueen in forum Capturing and VCRReplies: 6Last Post: 24th Mar 2012, 14:49 -
Sony Vegas Pro mpeg rendering size larger than movie studio
By bbbbbbb45 in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2012, 13:31 -
Vegas Studio stopped ID'ing date/time of initial recording when capturing
By mrmarley in forum Capturing and VCRReplies: 5Last Post: 9th Jul 2009, 23:42 -
Movie Vegas Studio 0x0050 MPEG-1 Layer 2
By hespinoza in forum Newbie / General discussionsReplies: 3Last Post: 27th Jan 2009, 00:29 -
Sony Vegas Movie Studio/DVD Architect Studio
By DJL82 in forum EditingReplies: 8Last Post: 1st Feb 2008, 16:14
