I have some MKV files. I want to convert them to AVCHD format. I do not want to burn on a DVD-R, DVD+R, or BR.
I read on the Samsung site that it does play AVCHD files.
How do I get to play from USB flash or USB external hard drive?
I can not seem to get it to play.
Does the file structure need to be in certain form?
Use multiavchd. Output to usb format.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I did that but it does not play it? Do you need to go in a special menu?
I have no idea about your particular BluRay player, but my Momitsu BluRay player cannot play anything that multiavchd creates. The only thing that works for me is to use tsmuxer to create AVCHD discs.
Also, you need to be sure that AVCHD is actually supported for playback via USB devices. It may only be supported on discs. The manual will tell you.Last edited by jman98; 25th Oct 2010 at 19:19.
There is nothing in the manual.
What do you tick in TSMUXER to creat AVCHD discs? -
There's an option in tsmuxer to produce AVCHD discs. If click on the word "tsmuxer" in my original post and look at the picture (click on that to enlarge it) you should see it clearly as one of the 5 output choices.
If your manual says nothing about playing AVCDH from USB then I would not assume it works. Some players use the USB port only for firmware updates.
Problem work Subtitle in Blu-ray Player Samsung BD-C6900
By Sheva in forum Newbie / General discussionsReplies: 7Last Post: 30th Apr 2012, 11:02 -
BD-C6900 cannot play BD-RE 25GB data disc
By mineownus in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Dec 2011, 12:15 -
Plays on my PS3 but not my Samsung BD-C6900 3D player what gives??
By gruvin2 in forum Newbie / General discussionsReplies: 20Last Post: 30th Jan 2011, 07:18 -
MKV Files and Samsung BD-C6900
By esabet in forum DVD & Blu-ray PlayersReplies: 3Last Post: 23rd Dec 2010, 14:15 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 10:15
