How do I clear the Recent Files list in Avidemux in Vista?
How do I prevent Avidemux from having this list?
I hope the developers will have an option to prevent from having this list.
From what I can gather the recent files list is stored in the config file, which is in the avi demux folder under users\youraccount\appdata\avidemux
This used to be a plain text file, so you could open it in notepad and clear the entries. It now appears to be in some custom format, so i don't know how you can edit it nicely. You could try deleting the file (or renaming as a test) to see if ti creates a new one. Of course this will also kill any custom settings you have.Read my blog here.
Many thanks. I am now using my cleaner to delete this Config file. Since I don't have any custom settings, it should be all right. For the info of other users, it is kept in C:\Users\username\AppData\Roaming\avidemux.
It would be nice if the developer add "no. of recent files to keep" in Settings and we can enter zero.
Avidemux crashes with many, many MP4 files. How to handle?
By Diana (Cda) in forum Video ConversionReplies: 6Last Post: 5th Feb 2017, 19:55 -
how to join files in Avidemux?
By FaisalKhan in forum Newbie / General discussionsReplies: 15Last Post: 19th Jun 2015, 11:29 -
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 20:07 -
how do i edit .js files for Avidemux?
By KneeRow in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2010, 16:20 -
combining VOB files with avidemux
By majax79 in forum Newbie / General discussionsReplies: 2Last Post: 20th Jul 2010, 01:17
