I am converting some VHS>DV captures in CCE, and I am noticing that there are always a few bitrate spikes that go above the maximum allowed. I use CCE VBR, and no matter what I set my maximum bitrate to, it tends to have several spikes somewhere that go over, just a few, sometimes only 1 or 2, but still, there are spikes. Because of that, I am finding I need to encode at a lower average bitrate and set my maximum lower than I want, just to leave it room to spike and still be within DVD spec.
I use Bitrate Viewer to analyze the .m2v files output by CCE, and there are 3 different scan modes - Second based, GOP based, and GOP enhanced. The spikes always show up in the second-based scan mode, but in GOP based and GOP enhanced, it is always evened out with no spikes, and the maximum is much much closer to the max I specified. I am wondering which method I should be scanning in to get reliable results? I don't want to worry about the bitrate being so close to the limit that playback could become a problem. So which should I be paying attention to - second-based or GOP based?
Example:
Second based
Average - 7482
Peak - 9220
GOP based
Average - 7482
Peak - 8423
GOP enhanced
Average - 7482
Peak - 8423
Notice how much higher the peak is in Second based mode. Once I add the AC3 audio it will be pretty close to max. If it wasn't for those couple spikes, I could increase the average and peak bitrates. But when I do that, the peaks are way to high in second-based mode.
Neither. Technically you need a buffer analyser
What you are looking at is instananeous bitrates per unit time, but this isn't what is important. What's important is how full the buffer is at that point in time, and how much data is incoming. It's an input vs output balance equation. If you have a buffer underrun, some player will stutter and skip
The spikes show in second based mode, because a second in duration will have 29.97 frames per second, but a single NTSC GOP will only have 18 frames max (ie. less than 1 second, thus less data, so a smaller "spike")
It's a good idea to leave some slack space - be more cautious, because some cheap DVD players don't even abide by the rules (they can skip/studder even at medium-high bitates even below 9Mb/s when it's clearly stated in the DVD specs that ALL PLAYERS MUST be able to decode 9.8Mb/s) -
Here's a slightly different opinion. If the max allowable bitrate is 10080 kbps including audio, video, subs, and overhead, then I don't see how you're very close to the max at all with a max bitrate set in CCE of 8500 (?). Even if you're using DD 5.1 audio at 448. I set my maxes in CCE at 9500. Haven't you already been told to author using Muxman, at least as a test? If it authors without incident, you can be assured it's within spec. And I wouldn't pay any attention at all to the second based one.
DVD Bitrate Viewer for Mac OS X???
By bendermac in forum MacReplies: 8Last Post: 17th Nov 2011, 08:58 -
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Looking for FLV bitrate viewer
By kevin3d in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jan 2008, 17:30
