Although I am far from a pro at DVD Authoring, this just seems like a FANATSTIC program; However, apparently I have a problem with the final burning process. I've attempted to convert 2 titles so far, but each time, the burn process aborts about 2/3 of the way though. I end up with various results on the DVD; 1 burned but had audio delay; 1 Burned nicely, but there was no menu or chapter but did play well.
I went back to ConvertXtoDVD to verify a few things and it burned as usual.
I've inserted the LOG from an Aborted burn below this text.
I would really appreciate some help with this as it's a great program that I'd like to use instead of the various others I have.
LOG:
<10/22/2010 10:53:50 AM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: Burn DVD
DVD Label: DVD
DVD Menu: No Menu
Output Folder: C:\Documents and Settings\Master Satan\Desktop\Joe Dirt
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
Video Resolution: 1
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
PAL SpeedUp: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
DVD Audio Language: EN - English
DVD Subs Language: EN - English
DVD Subs Font: Tahoma 18pt Bold
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: E: HL-DT-ST DVD+-RW GSA-H73N B103
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Save General Settings: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
TITLE 1 SOURCE FILES
Video: C:\Documents and Settings\Master Satan\My Documents\Downloads\Joe Dirt.2001-DvDRiP[x]\Joe Dirt.2001-DvDRiP[x].avi
Info: xvid - 960 kbps - 640x480 - DAR 1.333 - 29.97 fps (CFR) - - 1:31:10 hours - 163949 frames
Audio 1: C:\Documents and Settings\Master Satan\My Documents\Downloads\Joe Dirt.2001-DvDRiP[x]\Joe Dirt.2001-DvDRiP[x].avi
Info: MPEG-1 Audio layer 3 - 128 kbps - CBR - 2ch - 44100Hz - 1:31:09 hours - Internal
Subs:
[MediaInfoLib - v0.7.35]
AVISYNTH SCRIPT
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("C:\Documents and Settings\Master Satan\My Documents\Downloads\Joe Dirt.2001-DvDRiP[x]\Joe Dirt.2001-DvDRiP[x].avi", CacheFolder="C:\DOCUME~1\MASTER~1\LOCALS~1\Temp", VFR=false)
Audio = A2DAudioSource("C:\Documents and Settings\Master Satan\My Documents\Downloads\Joe Dirt.2001-DvDRiP[x]\Joe Dirt.2001-DvDRiP[x].avi", CacheFolder="C:\DOCUME~1\MASTER~1\LOCALS~1\Temp")
Video = Video.ConvertToYV12
Video = Video.Lanczos4Resize(720,480)
Audio = Audio.SSRC(48000)
AudioDub(Video, Audio)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 1-pass
Target Video FileSize: 4234.6 MB
HCenc Parameters: -ini "C:\DOCUME~1\MASTER~1\LOCALS~1\Temp\DVD_0_Joe Dirt.HCenc.ini"
HCenc ini file:
*INFILE C:\DOCUME~1\MASTER~1\LOCALS~1\Temp\DVD_0_Joe Dirt_1.avs
*AVSRELOAD
*OUTFILE C:\Documents and Settings\Master Satan\Desktop\Joe Dirt\DVD_0_Joe Dirt.m2v
*LOGFILE C:\DOCUME~1\MASTER~1\LOCALS~1\Temp\DVD_0_Joe Dirt.HCenc.log
*MAXBITRATE 9000
*1PASS
*BITRATE 6494
*PROFILE BEST
*ASPECT 4:3
*PROGRESSIVE
*TFF
*BIAS 60
*DC_PREC 10
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<10/22/2010 11:31:00 AM>
END VIDEO ENCODING OPERATIONS
A2DVideoSource: FFmpegSource2 (cache off)
Created File: C:\Documents and Settings\Master Satan\Desktop\Joe Dirt\DVD_0_Joe Dirt.m2v (3390.6 MB)
<10/22/2010 2:34:20 PM>
START AUDIO ENCODING OPERATIONS (Track 1)
Wavi+Aften Parameters: "C:\DOCUME~1\MASTER~1\LOCALS~1\Temp\DVD_0_Joe Dirt_1.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Documents and Settings\Master Satan\Desktop\Joe Dirt\DVD_0_Joe Dirt_1.ac3"
<10/22/2010 2:41:09 PM>
END AUDIO ENCODING OPERATIONS (Track 1)
A2DAudioSource: DirectShowSource
Created File: C:\Documents and Settings\Master Satan\Desktop\Joe Dirt\DVD_0_Joe Dirt_1.ac3 (125.2 MB)
OUTPUT AUDIO INFO: AC3 - 192 kbps - CBR - 2ch - 48000Hz - 16bit - 1:31:10 hours
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "C:\DOCUME~1\MASTER~1\LOCALS~1\Temp\DVD_0_BatchMux .ini"
BatchMux ini file:
-d "C:\Documents and Settings\Master Satan\Desktop\Joe Dirt\DVD_0\VIDEO_TS"
-mxp "C:\DOCUME~1\MASTER~1\LOCALS~1\Temp\DVD_0_MuxMan.m xp"
-l "C:\DOCUME~1\MASTER~1\LOCALS~1\Temp\DVD_0_MuxMan.l og"
-muxman "C:\Program Files\AVStoDVD\MuxMan"
-prio LOW
-v "C:\Documents and Settings\Master Satan\Desktop\Joe Dirt\DVD_0_Joe Dirt.m2v"
-vidmode 4:3
-a1 "C:\Documents and Settings\Master Satan\Desktop\Joe Dirt\DVD_0_Joe Dirt_1.ac3"
-a1lang en
<10/22/2010 3:09:22 PM>
CHECK DVD SIZE
DVD Folder (actual) Size: 3557 MB
vs Estimated Size: 4450 MB -> 20.1% undersize
vs Assets Size: 3515.8 MB -> OK
END DVD AUTHORING OPERATIONS
Created Folder: C:\Documents and Settings\Master Satan\Desktop\Joe Dirt\DVD_0 (3557 MB)
<10/22/2010 3:09:27 PM>
START DVD BURNING OPERATIONS
ImgBurn (DVD) Parameters: /mode isobuild /buildmode device /src "C:\Documents and Settings\Master Satan\Desktop\Joe Dirt\DVD_0\VIDEO_TS" /dest E: /volumelabel "DVD" /speed 4x /erase /testmode no /verify no /noimagedetails /start /waitformedia /close
<10/22/2010 5:59:25 PM>
PROCESS ABORTED DURING DVD BURNING OPERATIONS.
CHECK LOG FILE <C:\DOCUMENTS AND SETTINGS\MASTER SATAN\DESKTOP\JOE DIRT\DVD_0.LOG> FOR MORE INFO.
Log file created by AVStoDVD Release 2.3.2
Closed Thread
That was one of my first thoughts, but I only use Verbatim DL. I then tried with TDK DVD+R DL, but since they burn just fine using DVDFab or ImgBurn, I have to assume the disc's are not the problem.
The audio delay only happened on one of the projects but I think that was not finished being burned . . .?
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2014, 11:24 -
AVStoDVD ERROR DURING OPERATIONS ('DVD Authoring operations' Section): 0
By avitodvdbabe in forum Authoring (DVD)Replies: 0Last Post: 22nd Oct 2011, 16:14 -
No audio when burning dvd using AVStoDVD (log posted)
By aikipaul in forum Authoring (DVD)Replies: 4Last Post: 4th Oct 2010, 11:15 -
DvdShrink process stuck after burning to dvd .
By fibola in forum Authoring (DVD)Replies: 8Last Post: 19th Sep 2008, 11:17 -
Any suggestions for getting educated on burning process?
By Cathyq in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 08:44
